Vsc
Old 02-25-13, 09:36 AM
gregcwert
gregcwert's Avatar
Default Vsc
What is vehicle swirl control?
Old 02-25-13, 09:56 AM
JAB
JAB's Avatar
You mean vehicle stability control.
Old 02-25-13, 10:22 AM
gregcwert
gregcwert's Avatar
the vsc light was on , on my rx300 and my scan tool said swirl control? with code 1346
Old 02-25-13, 11:15 AM
hypervish
hypervish's Avatar
Did you recently have the timing belt changed?
Old 02-25-13, 12:38 PM
gregcwert
gregcwert's Avatar
Default belt
i put a new belt on it, i marked the belt and pulleys and then marked the new belt so i knew for sure it was 100% correct. and also checked the 3 timing marks and they were 100% on the money
Old 02-25-13, 12:42 PM
hypervish
hypervish's Avatar
Check it again.
The CEL 1346 points to skipping teeth or a stretched out timing belt.
Old 02-26-13, 12:32 AM
code58
code58's Avatar
Originally Posted by hypervish
Check it again.
I agree with Hyper. Not judging but it wouldn't be the 1st. time someone was "certain" something was dead on when it wasn't. Not likely your new belt is "stretched" so I'd look at the timing marks again. A lot of people don't realize the engine slants to the rear so the crank mark doesn't point vertical but rearward.
dbarber45
14
10-18-16 11:41 PM
boatable
06-03-15 11:24 AM
BDSL
06-02-12 03:14 PM
gmann
10-17-08 12:37 PM
sxwk12
04-23-05 11:59 PM
Quick Reply: Vsc
