Need help please
Sorry OP .. this thread seems to tilted towards tools ...
Personally, I have issue with the hardness/softness of the bolt-head/nut. Even with the 'right size' socket, if the ratchet has a slight tilt, it messes up the corners. I am slowly building my 6pt socket set.
Incidentally, service manual always show a "T" shaped tool [ratchet is a side ways "L"]. The "T" shaped tool would sit straight. Any one used it or seen it being sold?
Salim
Salim
My next try is the torx hammered into the head. Incidentally, I went to HarborFreight on Sunday and picked up an inexpensive bolt extractor set. The drill bits that come with that set are not particularly good, I have already broken one. This particular bolt is hard!
Salim
Well, I finally got the bolt out. Problem I was having was in drilling the pilot hole for the extractor. The drill bit that came with the Harbor Freight extractor set was of poor quality. I bought a high-quality bit (Rigid), hammered in the extractor, applied a long-handled wrench, and voila!
Good luck Jab. I have to replace my Rx's valve gaskets (both) also. Here is another tool : http://www.ebay.com/itm/NEW-Alden-8440P-Pro-Grabit-Broken-Bolt-and-Damaged-Screw-Extractor-4-Piece-Kit-/370792684017?pt=LH_DefaultDomain_0&hash=item5654f759f1
mr2j
Performance & Maintenance
13
12-10-16 01:45 PM
