Toyota Service?
From a local Toyota dealer website - the recommended 60,000 mile service for the Highlander- No brake fluid change recco'd with Highlander -
The following available services are for a 2001 Highlander with 60,000 miles.
Service Information
Recommended Services:
Replace engine oil and oil filter
Rotate tires
Replace engine coolant
Replace engine air filter
Replace limited-slip differential oil
Re-torque drive shaft bolt (Highlander, 4WD RAV4)
Click to view additional services.
Service Request
Please check the box to the left of the service to request the service.
You may click on the service to view and print the coupon.
Any additional services or comments may be entered in the box below.
Express Lube with 19 Pt. Inspection
Expires 1/25/2003 $19.95
Balance Wheels & Rotate Tires
Expires 1/25/2003 $34.95
2-wheel brake Special w/ front pad replacement
Expires 1/25/2003 $79.95
4-wheel alignment
Expires 1/25/2003 $54.88
Cooling System Service with Coolant
Expires 1/25/2003 $37.95
Service Information
Rotate tires
Service Request
4-wheel alignment
