RX Shuts down after car wash on engine
1st time writing on the forum. I have followed many threads from helpful members in the past year. This is a bit unusual. My Daughter's 99 RX300 AWD Had a bank 2 sensor 1 code and a misfire cylinder 3 code. I replaced the air fuel sensor by the radiator and the mileage went from 13 to 18 mpg. I then replaced the coil on #3 (fun spot to work on). The RX ran great and I was getting 22 mpg. I went to the car wash and washed off the engine compartment, replaced the vanity cover, and drove approx 25 miles and the car stopped running at an intersection. Towed it home and it turns over but will not start. Any Ideas? I hoped to contribute a fix on my 1st posting, but looking for help. Thank you, 99 RX 300.
There is little point is stating the obvious that one should not wash engine compartment. Always use compressed air.
You can still use compressed air to blow away pooled water (if any).
Usually with 25miles of driving moisture evaporates due to heat.
I would take out lug #2 and lay it on the top of the head and see if there is spark as you crank the engine.
Salim
Salim
(You actually have to be careful with using compressed air even because in the wrong place the static electricity generated by the compressed air can also cause damage to electronic components)
Thank you for stating the obvious . I learned the hard way, different from the cars of the 70s and 80s. Will view the ciol on 3 after pulling it to see. Thank you, (all washed up).
Salim
Salim
RX ran for a day. No spark now.
RX ran awesome and started a day after my post. Then died at an intersection again. No Spark on the #2 lug. With key on I moved the wire harness above the timing belt cover . I heard a click by the battery, so I tried to start the car and it ran for a few min. Shut down again. Lug #2 no spark, tried moving harness gently and no restart. Checked all connections around the area I previously worked on: #3lug coil replacement, changed out O2 sensor (bank 2 sensor 1). No CEL after that. Washed engine then recurring engine shutdown, now shut down. Thank you for the (check for spark idea... no spark. All washed up...
Next logical place to look would be swap the ignition coil ... check 12v on the + termial
Camshaft position sensor
crankshaft position sensor
ECM
Salim
ECM
Salim
Not Grounded
Thank you all for the help. 99 RX runs great found a ground wire I did not put back on the manifold. That is why it shut down. Now getting a 0420 for catalyst. I do not have to pass an emission test here. I am now getting 23 mpg. Is the Cat a major concern? Thank you, back on the road.
Onitlex96
RX - 1st Gen (1999-2003)
08-29-11 03:49 PM
mtom01
03-17-10 05:21 PM
