Power steering squeal at startup 99Rx300
Hi yall, My 99RX300 power steering belt tends to squeal at start for a minute and then the noise goes away. The fluid level is up so what is the best way to get at and adjust/replace the belt ? (Judging by the pump location I'd say crawling underneeth from the passenger side)
Regards, Chet
Regards, Chet
Power steering pump has the pivot. If you crawl under the passenger side there is a plastic piece in the wheel well that can be dropped .. and if you take the wheel off you can see everything clearly.
I would suggest that you get tool that pushes between the two pulleys and I had a hard time finding a place to create tension on the belt.
Salim
Salim
PlatinumV8
07-06-15 01:11 PM
2jznosht
Performance & Maintenance
10-14-13 08:22 AM
