Rear Obstacle Sensing Gadget
Hello,
I wonder if any of you have installed any kind of aftermarket
rear obstacle sensor thingie on your RX300?
Are they any good?
Are they any good?
I've done some research and will be getting the 'ROSTRA" unit.
http://www.justaskus@sotelectronics.com/src_backup.php3
Thanks for the info.
I was thinking about getting the same unit.
However, one of the local installer here is asking
for $499 for the unit and installation.
I believe the unit itself is only about $250.
(for the pro, it should take no more than 30 minutes so that works
out to be $250 per 1/2 hour or $500 per hour - man,
i am in the wrong profession).
Perhaps i should install the thingie myself (looks pretty
easy). Does not relish the prospect of taking off the
bumper myself, though.
having been a professional mobile electronics installer for 12 years, i can tell you that it will surely take more than 30 minutes to install that, you enginerd types think everything is easy but try and drill 4to5 precise holes in your rear bumper and wire up the entire system in 30 minutes. my shop charges $50 per hour and 3-4 hours would be the right amount of time too have it truly professionally installed
Hello MrPeabody,
Most likely, you are correct.
At any rate, I believe i saw this 30 minutes number in one of
the Rostra disti's web site.
PS: We enginerds think it should take 30 nano seconds
to do this. And the enginerd's manager probably
think the actual time should be more like 3 nano-second.
![Embarrassment](https://www.clublexus.com/forums/images/smilies/redface.gif)
jgcec
01-10-17 02:15 AM
Desertman
05-15-16 02:12 PM
Stage3
15
10-10-08 08:55 PM
