Transmission.....Drain or Flush
You need to find a good local mechanic. Those chain shops like Midas and Amco are hit or miss.
Listen to what the folks are telling you here. You NEED to get rid off that "milky red" crap. You can either do it yourself or pay someone do it for you. Instructions are simple: drain and fill, repeat until the crap is out...
Salim
I would "self-pump" at least 14-15 qts even if the fluid looked good at 10-12 qts. As I posted before, I would inspect a week later and repeat if I saw even the slightest evidence of water contamination.
Morning,
Just got off the phone with another repair shop and when I asked for a fluid exchange, he flat out told me he didn't have the time or space to pump out 3qts stop refill and repeat. I'm going to call around some more, but in the meanwhile should I just park it?
Second mechanic I just called said too risky may burn out the gear in the process.
They are the oil and lube place around the corner. I went to Midas first, but they would only do the machine flush. My mechanic drove it a couple of blocks, checked the fluid and said it was fine. He said the water would evaporate. I checked the Haynes manual and it was like reading chinese. Am I going to have to go to ammco or worst the dealer?
Seems like a no win situation. In between pros and cons of power flush vs keeping what you have in the system.
Any estimate as to what is the water - T fluid mix ratio or percentage ... Or how many quarts of Tfluid were added at time to swap? I think a dry system needs 16qts of Tfluid.
IMHO (no guarantees implied) at this stage, static water does more damage. So driving is better option. I have very limited knowledge when it comes to transmission. I would talk to the folks who sold you the transmission and ask for their advice. If they power-flush, then do so. At least you can tell them you followed their advice.
Salim
Salim
Salim
Salim
Yep, either the power flush, or the trans line flush. (preferably the latter one)
bjz3638
RX - 1st Gen (1999-2003)
30
08-13-08 12:11 PM
