Transmission.....Drain or Flush
Hello,
I just replaced the transmission in my 2001 Lexus RX 300. I brought a used tranny from a junk yard with 89k miles. No telling how long it has been sitting. The shop recommended a transmission flush within the next 2-3 days because they found water in the transmission. After reading these post, owners have mixed feelings about the flush. I know the shop that installed my trans are good at that but not specific on individual car models. This morning, I realize that the 1st to 2nd gear has a slower response time than my old transmission. Any suggestions would be helpful. thx
Hello,
If it`s not a reverse flush, it might be okay. And only because of them finding some water in there. Normally I would only suggest drain/fills. As far as the first to second delay, my 2001 had that issue and the only thing that got rid of it was Castrol multi import vehicle fluid or the Wolfs Head universal fluid. Shifted great then.
lexus114,
The transmission shop recommened a flush, they said they did not have the flushing equipment (whatever that might be) But what's a reverse flush?
Morning,
I did check the fluid this morning and it was milky red, more pink. I think I will try the fluid drain. Is it the same as draining oil from the motor?
Salim
I wish I had asked the shop before I paid....They go after big money they give you a hard way to go when you want simple stuff done. Is this something that a general mechnic can do, open the loop that is.
Salim
Meaning as long as the flush direction goes in the same direction as the fluid normally goes. I think there are/were some machines out there that went in a reverse flow direction.
I had the drain and fill done this morning. The fluid is still milky red. They suggested I take it back to the transmission shop saying they were wrong for not draining the water out before they installed it. They also mentioned the water may have eroded the transmission all together. Finally they told me to come back and two or three weeks to drain it again. It still has some hesitation in first gear. If I'm coming to a stop and accelerate while rolling, it jerks. All other gears are fine.
Who is "they"?
Did you read the post about how many drains and fill will be needed to replace about 98% of the original?
I hope you did not get a transmission that was flooded.
Salim
Salim
They are the oil and lube place around the corner. I went to Midas first, but they would only do the machine flush. My mechanic drove it a couple of blocks, checked the fluid and said it was fine. He said the water would evaporate. I checked the Haynes manual and it was like reading chinese. Am I going to have to go to ammco or worst the dealer?
You need to find a good local mechanic. Those chain shops like Midas and Amco are hit or miss.
Listen to what the folks are telling you here. You NEED to get rid off that "milky red" crap. You can either do it yourself or pay someone do it for you. Instructions are simple: drain and fill, repeat until the crap is out...
