Substitute to T-IV Transmission Fluid
Old 07-30-13, 06:17 PM
kalali
kalali's Avatar
Default Substitute to T-IV Transmission Fluid
Sorry if this has been discussed before but what is better substitute that is readily available for a tired RX300 with 162K miles? Been using the Toyota T-IV every 15K miles for the past 80K miles but would like to switch to something more suitable for "high mileage" application.
Thanks.
Old 07-30-13, 06:55 PM
hypervish
hypervish's Avatar
Keep using T-IV if you like it. It is a suitable "high mileage" candidate. And, if it's worked well for 80k miles why change now.
However, if you do want to change. You can try Castrol Transmax Import Multi-Vehicle, I've been using it for about 65k miles now, and it work's perfect.
Old 07-30-13, 08:40 PM
thomas1
thomas1's Avatar
I have used Mobil 1 Synthethic Transmission fluid on my old RX300 for 80k without problems.
Old 07-30-13, 10:23 PM
salimshah
salimshah's Avatar
Received 1,073 Likes on 966 Posts
Thanks.
Are you experiencing any leaks or slips? In other words are you trying to address a problem?
Salim
Old 07-31-13, 05:30 AM
kalali
kalali's Avatar
Forgot to say its 2003. No slipping or leaks just a subtle jerking when reverse is engaged, especially when backing up on an incline. Not expecting a fix with the fluid change but thought a different fluid might help. I have been doing regular drain and fills since I first detected this issue and it has not gotten worse, or better for that matter.
Old 07-31-13, 06:45 AM
Lexmex
Super Moderator
Lexmex's Avatar
I have been using Redline D4, but as others mention there are a lot of things out there better than the Type IV.
Royal Purple and Amsoil also make T-IV substitutes and the Royal Purple one you can find in most auto parts stores along with the Mobil 1 ATF.
Old 07-31-13, 06:51 AM
lexus114
lexus114's Avatar
I found the Wolf`s Head multi vehicle Synthetic fluid, and the Castrol fluid worked the best in the 2001 I had. Also took away most of that delay it had from 1st to 2nd gear shifts.
Old 07-31-13, 07:50 AM
salimshah
salimshah's Avatar
The jerk on incline is due to driver negligence when parking.
Apply parking brake and then move the shifter to "p" and turn off ignition.
Start, move shift lever to R or D and then release the parking brake.
Another good driving/parking habit would be curbing the wheels on an incline. I live in the hilly part of central Texas and see too many vehicles parked with un-curbed wheels.
Salim
Old 07-31-13, 04:01 PM
jbl-1985
jbl-1985's Avatar
I've used T-IV for the life of the car (first full drain and fill was done back in 2009 at around 40k miles. Regular drain and fills after I bought the car in 2010. Transmission has always been smooth shifting with it. Sure there are probably better fluids out there, but I'm cut from the team that says "if it ain't broke don't fix it".
Old 08-01-13, 05:15 AM
kalali
kalali's Avatar
Salim
Thanks all for the feedback. Appreciate it. Regrading the jerking in reverse, I experience the jerking when I apply throttle with the gear fully engaged in reverse as opposed to the one when the shift lever is moved from P to R. Nonetheless the use of parking brake is an excellent advice.
I think I'll try a different fluid next drain and fill just to see if it makes a difference.
Old 08-01-13, 05:56 AM
salimshah
salimshah's Avatar
My bad!
I would suggest, having the rubber mounts examined. In reverse a lot of power gets transferred and any excessive give in the mounts will cause noise and a jerk.
Salim
Old 08-01-13, 06:37 AM
Baetke
Baetke's Avatar
Just curious, why are these alternative ATF's "better" than T-IV and do you do a complete flush or just a drain/fill to gradually replace the T-IV?
Thanks
Old 08-01-13, 06:47 AM
salimshah
salimshah's Avatar
Thanks
Are you concerned about co-existence of two different fluids?
Which fluid is better? I am glad that you asked in this forum where it would not turn into which religion is better sort of discussion
Keep all the variables in mind
Price
Longevity
Availability
Specs
Environmental impact
Co-existence
and many more
Salim
Old 08-01-13, 07:35 AM
lexus114
lexus114's Avatar
Thanks
Because they are Synthetic/Synthetic blend fluids. The Toyota fluid is not. Which theoretically means they should hold up better.
Old 08-02-13, 04:45 AM
kalali
kalali's Avatar
Good point here. Would it be OK to have the T-IV mixed with the different/new fluid?
Quick Reply: Substitute to T-IV Transmission Fluid
