new symptom popup after ATF and filter changed
just followed the guide on the 1st page and got ATF and filter changed. really time consuming because I made 2 mistakes -- 1st time forgot o-ring, 2nd time forgot magnetic. what a pain to do a screw-and-unscrew job.
PROS: notice that acceleration is better than before.
CONS: but since today, when I just start the car, before temperature comes up, when I stop the car before stop sign or traffic light, the car begins to shake a lot. After drive for a while, temperature comes up, there will be no shake when I stop the car. ANY idea about what's going on?
BTW, no CEL light pop-up. I also check that ATF is not overfilled.
Last edited by salimshah; 08-20-13 at 10:26 PM. Reason: fixed pros and cons ,,, salim
Check the level again with min 15 of driving on level surface, parking brake on, gear in Park and engine running.
Salim
Salim
does that mean it's overfilled?
How much past full is it?
If it isn't past the "T-IV" lettering I wouldn't worry about it. You can always drain a bit out, by loosening the drain plug a thread or two.
sereousl
02-24-15 05:19 AM
