2001 HID headlights assemblies.
I've been looking for over a year and a half now for some new headlight assemblies that will fit my car. Everyone that is sold online is for the halogen version of the headlights, my car has the connections for the HID version.
Currently I have 2 of the halogen version assemblies installed with the HID bulb hot-glued into place (yea, I know) and the ballast is taped and hot-glued onto the bottom of the assembly.
Has anyone been able to find new HID headlight assemblies anywhere online?
You can find them on ebay but they will be extremely expensive.
http://www.ebay.com/sch/i.html?_from...dlights&_sop=3
You are better off retrofitting your current lights if you REALLY want HID's.
It's not that I want HIDs, it's that the connections coming from my car only fit HIDs. Plus I no longer have the old housings since they were mangled in am accident.
It seams like they just don't make the housing that fit the HID bulbs.
I picked up a set of halogen headlight assemblies from some guy on craigslist for $40.
But yes, there is a difference. The halogen version of the headlight assembly has different socket's for the main bulb, it won't fit the HID bulb at all. You can kind of take off the small plastic ring (there's three screws on it) that's supposed to hold the halogen in place, place the HID bulb into the hole (CAREFULLY) and then reattach the plastic ring onto the assembly. Hot glue the whole thing afterwards, for water-proofing.
There's this other connector that the HID had, wasn't a bulb, excuse my lack of knowledge here but it was some kind of little rod that can get pushed in. I'm assuming it's a front impact sensor. But yea, the halogen version I got didn't have a slot for that either.
There is also no little plastic bay that holds the HID ballast on the bottom of the assembly. Everything else matches fine. It fits onto the frame and the other bulbs (high beams, blinker, parking light) just fine. Just that damn main bulb.
If you're replacing your own assemblies, be warned that it's a real pain in the ***. There are two nuts that you have to take off that you can only gain access to through the wheel well. So you need to take the wheel weel cover off and use a wrench extension then kind of feel around in there while in sitting in an awkward position on the ground.
See this link in the forum. Last reply should help.
https://www.clublexus.com/forums/rx-...nightmare.html
Good luck!
Good luck!
Alfred08
06-23-17 06:22 PM
