castrol transmax full synthetic multi vehicle atf
just look this up full synthetic atf not semi synthetic the sheet says type t-iv jws 3309 approved which is what lexus approves. all that i have read on this forum people say to use the multi vehicle semi synthetic atf anybody use it .
thanks i found this on mt Mercedes forum found it interesting and thought you all might be interested in it Subaru ATF
• Subaru ATF-HP
• Toyota / Lexus Type T, T-III or T-IV
• Toyota WS
• Voith H55.6335.33 (G607)*
• Voith H55.6336.33 (G1363)
• Volvo 1161521 and 1161540
• VW TL52162
• ZF TE-ML-14B, 16L and 17C
• ATF 3403 M115
* Formal Approval
Valvoline has conducted in-house testing to support MaxLife ATF performance in these
transmissions. However,
it is important to note that, other than where we have formal approvals, these vehicle
manufacturers have neither
evaluated nor approved MaxLife ATF.
Valvoline stands behind all of its products, including MaxLife ATF. Use of MaxLife ATF
in transmissions where
recommended by Valvoline WILL NOT void the vehicle’s warranty. Vehicle manufacturers
are restricted by
federal law from including the requirement of the use of a specific brand or trade
name of product or service as a
condition of their warranty. The following is an extract from the Federal Trade
Commission’s web site on
interpretation of the Magnuson-Moss Warranty Act:
Valvoline has conducted extensive testing and has a long history of successful use of
MaxLife ATF in a broad range of
applications. In the unlikely event that you or your customer experiences any
transmission damage while using
MaxLife ATF, please contact Valvoline at 1-800-Team-VAL for assistance.
While MaxLife ATF is designed to meet the special needs of higher mileage
transmissions, new transmissions can
also benefit from its enhanced oxidation protection, shear stability, seal
compatibility, and anti-shudder protection.
Many consumers have chosen to take advantage of this level of performance in newer
transmissions.
Valvoline currently does not recommend MaxLife ATF where certain specific low
viscosity ATFs are called for.
These include Mercedes Benz NAG-2, ZF Lifeguard 6 and 6 Plus, and AUDI G055-162-A6 and
G055-005-A2
applications.
Valvoline does not recommend MaxLife ATF for use in most continuously variable
transmissions (CVTs) unless
specifically noted nor in automatic transmissions where Ford Type F fluids are
recommended.
Sincerely,
Thom Smith
Technical Director, Valvoline Brand
Ashland Consumer Markets
noticed that it states Toyota t-lv and that this is also a full synthetic atf oil
• Subaru ATF-HP
• Toyota WS
• VW TL52162
• ATF 3403 M115
* Formal Approval
are restricted by
transmissions.
G055-005-A2
applications.
recommended.
Sincerely,
Thom Smith
MASSMINI
RX - 1st Gen (1999-2003)
15
07-30-11 12:08 AM
ae, atfplus, castrol, compatible, full, luxes, matf, meets, multivehicle, semi, synthetic, tiv, transmax, transmaxtm, volkswagen
