2000 RX300 idle problem
Hello everyone first off let me start by letting you guys know what's been going on. I own a 2000 lexus rx300 2wd with 209000 miles the truck was running fine until I noticed a little idle while in a stop but didn't care much for it so decided to give it a tune up. Prior to this I had the CEL for system to lean. After all this the trucks brakes starting getting hard and the truck will not accelerate no more than 40 in the freeway so I hooked up the scanner and turned out that I got the following codes:P0171,P1130, P1135, P1349. I got allthe codes fixed no more CEL but the truck still idles and I'm lost any help will be greatly appreciated I've tried seafoam and nothing thanks in advance
Salim
There is a DIY. Look at the list of DIY
Salim
Salim
My suggestion is to take it off and do it right. Often when cleaned "on the car", it can be less than satisfactory and the problem return in the next weeks or months. Pretty hard to clean effectively for long term success on the car.
The IACV cleanup is when all other issues have been addressed. No CEL.
Salim
Salim
Ok guys I did the throttle body clean up and the iacv and the truck still has the small idle problem a guy told me the next step would be to replace the IACV get it from tue dealer. Coukd this be? Or what else can it be?
