P0420 Code
P0420 Code
Hi Everyone,
My exhaust started to make some noise. Couple weeks after that i got a trouble code 0420. I didn't notice any power loss. Can it be just just a crack or a bad gasket in the exhaust system?
Thank You
Thank You
Does the RX sound different? any droning especially at fast idle?
The code means the computer isn't seeing enough difference between the precat O2 sensor and the post cat O2 sensor. The way to know for sure is to put it on a scanner and compare the O2 data to the FSM's spec and a visual and auditory inspection of the exhaust.. But the likely culprits are 1)the cat, 2)exhaust leak, 3)one or both O2 sensors.
chi123
08-14-12 06:27 AM
