Time adjust of JDM version (Harrier)
Im having jdm version(Harrier) of lexus rx 300, Its center display shows wrong time. No clock button on the panel. Tried to reset by disconnecting battery terminals, but it didnt work. Please let me know how to adjust the clock time.
Best regards.
Best regards.
go here
http://drivers.lexus.com/lexusdriver...manual-search#
Select your model year and type "clock" in the search terms.
It is different for nav vs base. (pretty sure)
You can download sections of the owner's manual and save/view them in PDF
I think the PDF you will need will be <model year> Interior equipment.pdf
thanks for quick reply, i went through your posted link. it has only for standard player. I think export version equipped only with non navigation player. so no instruction for this matter on lexus rx manuals. It might be on japanese harrier manuals, but i dont know japanese and couldnt find manual here.
here is the model,
![](http://image-cdn.beforward.jp/files/pictures/201311/175820/BF180520_25.jpg)
here is the model,
![](http://image-cdn.beforward.jp/files/pictures/201311/175820/BF180520_26.jpg)
https://www.clublexus.com/forums/rx-...-the-time.html
Not sure if this helps.
It looks like you have to have the NAV working to set the clock.
Found this too
"The clock on 1998 Harrier is auto adjusted following GPS system. When the car is sold in Japan, location data is set in Japan and GPS system auto set time to Japan time. Impossible to adjust unless you've got equipment to re-program the GPS system."
Found this too
im always misleading by that inaccurate time. is it possible to change it to non navi player. these days it is available in ebay @ cheap price , here is the link, is it possible to change without any issue, i really need fuel consumption display, it helps me to achieve around 10km per liter, if I get head unit from us named as lexus ,that fuel consumption reading will be mpg instead of km/l ?
http://www.ebay.com/itm/1999-2000-2001-2002-2003-Lexus-RX300-86110-48030-Center-Dash-Info-Diplay-Vents-/281165756140?pt=Motors_Car_Truck_Parts_Accessories&hash=item4176c8f6ec&vxp=mtr
SoCalRX
RX - 4th Gen (2016-2022)
01-04-18 09:56 PM
