Factory Radio Power/Volume control broken
hi guys .. searched the forums but found nothing on this topic.
about a couple of months ago the spring action to turn the Power On/Off on the Radio was broken. It became really soft and was not bouncing back. It was fine for a while - it meant I have to pull it up manually.
But not it has become so bad that when I turn the Volume up/down it turns off. And even the slightest touch seems to turn the radio off.
It has come to the point where I need to find a solution.
What are the options ?
Maybe before you go out and start buying parts, you can pull out the part and see what's wrong with it first.
Though it's intensive for a single button, you can follow this post to see how it comes out.
