radio button and switch lights
I unsuccessfully tried to replace the burned out "D" bulb in the gear selector (turns out bulb was good, fuse was bad, and new fuse didn't get bulb to light) but now I realize that none of the radio buttons or other ***** and switches light either, as these do here in this stock photo:
![](https://upload.wikimedia.org/wikipedia/commons/8/81/Lexus_RX_300_cabin.jpg)
Is there a fuse that handles all of those at once??
Does your display light up? What about your interior lights?
If I recall correctly, the fuse for the dome lights and the center console run off the "DOME" fuse in the engine fuse box.
More info here
More info here
I unsuccessfully tried to replace the burned out "D" bulb in the gear selector (turns out bulb was good, fuse was bad, and new fuse didn't get bulb to light) but now I realize that none of the radio buttons or other ***** and switches light either, as gazi's do here in blue:
![](https://www.clublexus.com/forums/attachments/rx-first-generation/210867d1306032263-led-upgrades-to-interior-blue-light-and-lighted-door-sills-dsc06999.jpg)
Where is he coin box? Also curious about the switch to blue lighting. Or is it the photo/flash that made it look blue instead of green?
Salim
Read this thread to see gazi's mod to blue leds. That's where OP's pic came from.
And remember, there are two fuse boxes, one behind the coin case and one in the engine bay. Check the other if you can't find the fuse in one.
More info here
More info here
![](http://img.photobucket.com/albums/v115/eddieo45/Mobile%20Uploads/photo_zps7b66135c.jpg)
![](http://img.photobucket.com/albums/v115/eddieo45/Mobile%20Uploads/photo_zpsaf076890.jpg)
do the switches/buttons on the center cluster work (ie: climate control & radio controls)?
check for blown fuses in both the engine bay and the driver side auxiliary box.
if nothing there, you might have check for a loose connector behind the center cluster panel.
[IMG]
![](http://img.photobucket.com/albums/v115/eddieo45/Mobile%20Uploads/photo_zpsd6f6b6d6.jpg)
The dimmer **** on the left of the instrument panel adjusts the brightness for both the instrument panel and the radio buttons.
Try turning the **** all the way right.
Failing that, since all the radio button lights brighten and dim together there could be a single bulb to light all of them.
You may have to take it apart to figure it out.
SudoBailey (12-31-18)
