someone's opinion please spark plug
Old 01-28-14, 01:57 PM
edupim
edupim's Avatar
Default someone's opinion please spark plug
hi people.
my RX300 has 93 kmiles and i Don't know if i have to change then.
i took photos but i don't know to analyse them
below the photos
please tell me if is hour to change.
Attached Thumbnails someone's opinion please spark plug-2014-01-28-11.16.41.jpg   someone's opinion please spark plug-2014-01-28-11.18.14.jpg   someone's opinion please spark plug-2014-01-28-11.19.21.jpg   someone's opinion please spark plug-2014-01-28-11.19.35.jpg   someone's opinion please spark plug-2014-01-28-11.19.47.jpg
Old 01-28-14, 03:07 PM
Z07
Z07's Avatar
They look in pretty good shape for 90K mile plugs. I believe they are NGK iridium plugs made for Denso. I am not sure if that is original equipment or not but that is the exact plug that I use in everything that I can.
IMO you won't see any performance gain by replacing those plugs with new but unless you want to pull them and check them ever few thousand miles at this point, I would replace them.
I do not believe that an abrasive spark plug cleaner can or should be used with either platinum or iridium tip plugs so I would not try to clean them.
Old 01-28-14, 03:10 PM
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
Plugs should be replaced at 110k miles with and stick to OEM or do your research.
If you are not getting any misfires ... your call if you want to wait out another year or not.
You can clean them but dont try to gap them .. they will break.
Salim
Old 01-28-14, 04:00 PM
edupim
edupim's Avatar
my problem stiil 13.5 mpg (with ar conditioning on) my city is 1/2 san francisco 1/2 orlando
i have changed maf, cleaned admissions tubes, tire presure ok all light off in the dash
what about to change oil transmission (type 4)
Old 01-28-14, 04:05 PM
pheonix72
pheonix72's Avatar
They look pretty crappy; the tips a bit worn out and there are some evidence of high temp aging (on the ceramic bodies).
I would change them now! Your car will feel smooth idling and a bit more responsive when accelerate. I just changed them on my IS350 with 105,000 miles and definitely noticed the improvements.
Stick with Denso OEM.
Old 01-28-14, 04:09 PM
edupim
edupim's Avatar
i ll change with denso iridium
Old 01-28-14, 04:13 PM
kalali
kalali's Avatar
For me the answer is obvious. If I went through the trouble of removing the plugs, especially the rear ones. there is no way in hell I would stick them back in there. And to be honest, I don't think those plugs all look that good but I suppose you could just clean them if you really wanted to same a few bucks. Mine looked a lot cleaner after 103000 miles and I still replaced them for good measure. I seriously doubt if this would cure or even have any noticeable effect on your poor gas mileage though.
Old 01-29-14, 06:25 AM
Lexmex
Super Moderator
Lexmex's Avatar
Replace them, I've seen plugs like that before in Mexico when my Uncle and I would replace them and they won't do any more good.
Old 01-29-14, 06:40 AM
edupim
edupim's Avatar
i misunderstood. In your opinion do a have to replace or it is waste of money ?
Old 01-29-14, 06:48 AM
Lexmex
Super Moderator
Lexmex's Avatar
Put in new plugs, I think they cost like $10 maximum per plug in the U.S. and you only change them every 160K KM, so it is a small price to pay.
Old 01-29-14, 06:51 AM
edupim
edupim's Avatar
Lexmex,
once you said (if i m not wrong) to change the transmission ATF that will probable improve MPH
i m right that you said that ?
except to change the thermostat I did all and my mpg still 13.5 ( all light off and no code in scanner)
maybe the gas in brasil is below 70 octanes with some water blended.
Old 01-29-14, 06:52 AM
toyo
toyo's Avatar
Those belong in the trash!
Old 01-29-14, 06:53 AM
edupim
edupim's Avatar
ok decison done order posted in amazon.
thanks again
Old 01-29-14, 06:55 AM
edupim
edupim's Avatar
please, Toyo, what you mean? my english is poor
Old 01-29-14, 06:57 AM
edupim
edupim's Avatar
AH understud you said this sparkplus now belongs to trash ok good thanks
Quick Reply: someone's opinion please spark plug
