Sudden acceleration
Old 02-19-14, 04:56 AM
Avster
Avster's Avatar
Default Sudden acceleration
Hi guys a friend of mine has a Toyota harrier 3.0l and has been experiencing something strange when slowing right down say at a traffic light and then trying to excellerate the car just wants to take off at high speed it is scary and i am a bit worried as this is unusual does any one have an idea what could be causing this
Thanks
Old 02-19-14, 05:11 AM
ATLs460
ATLs460's Avatar
Any codes?
Old 02-19-14, 05:25 AM
hypervish
hypervish's Avatar
Clean the throttle body to see if it is sticking.
These cars do not have DBW so it's impossible for them to accelerate on their own because of an ECU problem. It would have to be something mechanical.
Old 02-19-14, 08:49 AM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
I would also check if the accelerator cable does not have any frays and is free of grime. Lot of places have a tendency to lube the cable and over time it becomes sticky. The other thing to check would be that there is a slack (1/8" to 1/4") in the cable before the butterfly wheel starts turning. [I know some folks have removed this slack].
Next task would be to see if the throttle body is free of grime. The butterfly can become sticky and not close fully/
Check engine mounts to make sure the engine is not shifting, causing the throttle cable to pull.
Salim
[Most of the unintended acc happens as the gas pedal is pressed ... not the driver is intending to do, but things like the floor mat etc make it happen]
Drivers must know and be prepared for un-intended acc. All must have a plan ... Brake, steer, shift to N, kill switch etc]
Old 02-19-14, 09:35 AM
jimbug
jimbug's Avatar
My gas pedal was sticking before I had the throttle body cleaned so as mentioned above I could see your problem could have the same cause. Cleaning it increases gas mileage 2 mpg if it was as dirty as mine, so it pays dividends to keep it clean.
Old 02-24-14, 12:43 PM
Avster
Avster's Avatar
Thanks for the info guys will get onto all that was mentioned really appreciate the response
96ghost
09-06-18 08:11 PM
Suneet
12
06-07-07 11:33 PM
GlobeCLK
10-28-06 08:46 PM
Splatsc300
SC400 / 300 Classifieds
06-14-05 12:14 AM
TRULUX
09-01-04 08:53 PM
Quick Reply: Sudden acceleration
