Help needed - Front Differential fluid change
Old 02-23-14, 02:45 PM
Stemmer
Stemmer's Avatar
Default Help needed - Front Differential fluid change
I tried to research this issue but got even more confused. On my other car I know there are separate fluid changes for rear differential, transfer case, front differential and transmission. On my '99 RX I am fairly certain that I have only had the rear differential and transfer case fluid changed with the belief the front diff is somehow connected to the transmission and share fluids (I also thought the maintenance schedule only mentioned inspection of transfer case and rear differential fluids but I can't find the book). After my last oil change the Toyota service adviser stated the mechanic recommended a front differential fluid change as the fluid was dark. I have an ATF drain/refill planned for the next oil change as I have that done every three oil changes. So the $64,000 question is whether there is a separate drain/fill for the front differential. Thank you in advance.
Old 02-23-14, 03:18 PM
carguy07
carguy07's Avatar
Front diff shares fluid with the tranny. There are two plugs to remove when you do a drain and fill, one is the tranny pan, the other is the front diff. I'll direct you to some pics in a second.
Old 02-23-14, 03:21 PM
carguy07
carguy07's Avatar
This should help:
The first pic shows fluid draining from the tranny pan and a hex wrench in the front diff plug. The second shows the front diff draining.
Old 02-23-14, 03:26 PM
carguy07
carguy07's Avatar
This is the transfer case, it takes gear oil.
Old 02-23-14, 04:47 PM
Stemmer
Stemmer's Avatar
Now that's an answer! Thanks Carguy!
Old 02-26-14, 05:30 AM
edupim
edupim's Avatar
but now i have a question. Why the rear diff is 75w90 and the front is atf typ4 iv . question . the viscosity is the same ?
Old 02-26-14, 06:13 AM
hypervish
hypervish's Avatar
The rear differential and transfer case take 75w90 gear oil.
The front differential shares ATF with the transmission, hence the term transaxle.
EDIT: It seems I misunderstood your question, Salim has the answer!
Old 02-26-14, 07:45 AM
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
Very very different oils.
The choice of oil has to do with environment, gaps between rolling objects, pressure formed to squeeze out the oil by rotating parts, emulsion/cleaners needed to move out debris etc. Another important factor is the loss of energy which is carried by the oil.
There is no pump in the rear diff. The gears sit in a bath of oil and viscous oil moves around by rotating gears.
There are other secondary effects like types of seals (how they react to oil) and outside (mud/air) exposure of the seals.
Salim
Old 02-26-14, 02:13 PM
edupim
edupim's Avatar
killed the doubt
Old 11-20-21, 12:54 AM
glenpointe
glenpointe's Avatar
You had the transfer case and differential backward. Differential takes gear oil, transfer case takes trans fluid.
Old 11-20-21, 12:56 AM
glenpointe
glenpointe's Avatar
the one share trans fluid is the transfer case, not differential. The differential connects to the drive shaft to the rear wheels. Any DIY for changing the oil for the front diff.?
Old 11-20-21, 11:20 AM
salimshah
salimshah's Avatar
This is my best understanding:
The transaxle in RX has the transmission and the front differential .. all enclosed in one casing. It couples the engine to the front two wheels. It has two low points for draining and one fill point through the transmission dip stick.
For AWD you will have a rear diff at the back.
Please correct me if I am wrong.
Salim
Old 11-20-21, 08:06 PM
glenpointe
glenpointe's Avatar
For what I've learned, transfer case usually attached to the transmission and commonly uses transmission ATF fluid. In the other hand, CV axles or axle shaft attached to the differential for spinning the wheels. Differential mostly uses gear oil not ATF fluid. Therefore, in the RX300, the unit attached to the transmission is the transfer case. I haven't seen a transfer uses gear oil. Transfer case only uses ATF fluid or special formulated fluid.
Old 11-20-21, 09:55 PM
salimshah
salimshah's Avatar
Your statement [in bold] is correct for rear differential in RX [AWD model]. The front diff (which is part of the transaxle) uses ATF which is shared with the ATF of the transmission for both AWD and FWD models.
Salim
User 3923
11-23-21 06:24 PM
RX3302004
10-25-15 07:21 PM
BlueCrabby
09-04-15 07:10 AM
Poqman
05-30-12 06:07 PM
96sc3
Maintenance
26
02-20-04 05:54 AM
Quick Reply: Help needed - Front Differential fluid change
