gas mileage - depends full or empty ? is it true ?
hi guys.
i have a felling that my rx spend more gas if the tank is empty.
is it true ? any comments ?
all the best to cl people
if anything it should spend less because a gallon of gas weighs in 6 lbs. as such an empty tank is carrying about 120 lbs less than a car with a full tank. what you are probably seeing is the fuel sender moving quickly showing the depleting gas tank as you get closer to the bottom.
