scanner
Old 05-02-14, 04:05 PM
elecinsp
elecinsp's Avatar
Default scanner
does anyone know of a good (reasonable) scanner that will work with the rx 300?
thanks
Old 05-02-14, 04:50 PM
carguy07
carguy07's Avatar
Cheap one will work if you just want to check and clear codes.
Amazon.com: Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles: Automotive Amazon.com: Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles: Automotive
Old 05-02-14, 06:29 PM
elecinsp
elecinsp's Avatar
thanks, thought they were more expensive
Old 05-03-14, 04:31 AM
kalali
kalali's Avatar
If it were me I'd pay a few more and get one that tells you the code and its definition. With that one you'll need to look up the description in a booklet. Of course, you could memorize all of them if you have real good retention...
Old 05-03-14, 07:30 AM
hypervish
hypervish's Avatar
I'd suggest getting an ELM 327 if you own a smartphone. The WiFI model will work with the iOS, bluetooth model will only work with Android.
Old 05-03-14, 08:16 AM
carguy07
carguy07's Avatar
I never found any value in the reader telling me what the code is supposed to mean. There are usually a few that are incorrect and the best way to find a "fix" is type the code in on a site like this and start reading.
Old 05-03-14, 10:54 AM
elecinsp
elecinsp's Avatar
thanks all for their reply
spierce
03-24-17 08:04 AM
valex
12-30-16 01:41 PM
diverchris
05-01-14 01:20 PM
macarong
08-09-10 09:39 AM
Quick Reply: scanner
