Rear Tire 245-50R20 and Front Tire 235-70R16
Hi
I run of issue when installing a Venza Rim in front of my RX300 1999 AWD...
Can I use combinations of Rear Tire 245-50R20 and Front Tire 235-70R16 until I found solution on the front.wheel ?[IMG]
Thanks,
Mike
Thanks,
Mike
If the outside DIAMETER of the tires is the same on all four I would think it should be ok as they will all be turning the same RPM at the same time. And that's the most important thing. Just guessing tho.
