Door lock and auto up window issues.
Hey guys
I recently replaced my master drivers switchboard.. I am having a couple issues since...
1.when I unlock the doors by pressing my key twice, my front passenger lock won't unlock.
2. when I go to lock the car, my driverside back door won't lock, nor my front passenger door, I have to do them manually.
3. my auto window up function works on all windows except my driverside front window.. it will go up but then it will go to the top and roll half way down..
I did some quick searches, but Im seeing if there is a reset for the window issue.. instead of taking the door apart again..
I am also trying to see if its reset on my key or if the door lock issues are purely mechanical..
thanks again.
thanks again.
Seems like your front passenger side door lock actuator motor is shot. Confirm by pressing the lock button from inside the cabin (not the lock ****) .. the electronic lock button.
Please read the owners manual. You have to reprogram the pinch protection circuit ... hold the up switch in up position till the glass moves all the way up.
Salim
Salim
