Transmission Flush - the Volvo Technique
When I owned a Volvo, a common trans flush method was to disconnect a trans cooler line, connect a hose to the line and run it to a bucket which you have marked with a 2-quart line. Start the engine and allow 2-quarts to run into the drain bucket, stop engine, put 2-quarts of new fluid into the trans. Repeat process until clean fluid was coming from the drain line. I understand the correct fitting to disconnect for the draining procedure is in the picture below (a prior picture posted depicted the wrong line). if disconnected, the fluid will flow-out of the rubber portion of that line. Is there a reason this would not work just as well on an RX? Wouldn't this procedure be better than just draining-out and replacing 4-quarts?
![](https://www.clublexus.com/forums/attachments/rx-first-generation/283201d1368373634-photo-diy-rx300-awd-transmission-fluid-pan-filter-change-rx300_oil_cooler_outlet_hose.jpg)
Last edited by pilot2; 09-11-14 at 02:29 PM. Reason: CORRECTING ERROR IN PRIOR MESSAGE
Nothing unique here. Similar process is posted here.
The process is essentially the same as repeat drain and fill (with an exception, which I will list in the last para below). What is accomplished is the fluid in the converter and cooler is also replaced.
What it does not do is remove the sediments which are collected at the bottom of the pan.
Salim
Salim
There is a DIY for that here: https://www.clublexus.com/forums/rx-...er-change.html
Some people do it, nothing wrong with the method. I like to introduce new fluid slowly, and I rather do it every 10k miles so it's continually being done. Rather than a flush at longer intervals.
I am not suggesting the foregoing is a substitute for occasionally pulling and cleaning the trans pan and filter, I am speaking of all the interim trans fluid changes between the pan/filter procedure.
Salim
Salim
I wonder if there is a standard valve that could be inserted into the trans line referenced such that with the valve in one position the fluid is flowing through normally and in the alternate position the fluid is redirected out another port to which a drain line would be connected. Thus, the system, irrespective of whether you also pulled the drain plugs, would be to simply turn the valve, collect two quarts, stop engine, poor-in two new quarts, repeat as necessary.
There are drain plug adapter available [for the engine oil pan for sure]. You can have one machined. Just be aware that down there, things can snag and catch on to the modified plumbing.
From manufacturer's point of view, they opt to provide some convenience. Lots and lots vehicles do not have a drain plug on the transmission pan. Reason is that transmission fluid need not be replaced or partially replaced at 60/80/90/100k miles (pick a number). It is like rear diff oil, which needs to attended to very infrequently. There are no contaminants getting in the fluid.
I personally follow the manufacturer's recommendation where replacing the majority of old fluid at one time is not done. I have shortened the interval a bit and at 100k dropped the pan [not required].
At the end, do what makes you happy/comfortable. There is no direct co-relation between tranny failure and % fresh fluid.
Lastly doing a trans & front diff drain is lot easier than changing oil filter in RX.
Salim
Salim
acklac7
Performance & Maintenance
12-20-17 10:03 AM
lserlohn
RX - 1st Gen (1999-2003)
01-29-12 11:31 AM
lexsc3
Maintenance
03-05-03 06:25 AM
