I searched to the end of the internet......
And I can't find where the seat ECU is located. I'm assuming it's under the driver's seat, but I have found zero posts to confirm it's location. Not even a photo on the Google...
You cant find it as it does not exist.
I think it is the main ECU that handles seat position. Lets see if other can confirm.
Salim
Salim
Do you mean seat motor? Why should the seats have/need an ECU? Seat memory is probably a small chip right around the setting switch.
No, the motors in the seat all work fine. There are a number of Seat Memory ECU's, ECM's on eBay, so I'm assuming there IS a separate computer for the seat memory.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/1400x1000/841861f_72a2b23c595821288776c08a78bcf094950ef159.jpg)
Module is PN 89710
I found it on the Sewell site,(item #89710) but can't figure out where it's supposed to be mounted...
Nevermind... It looks like it is mounted on the floor under the drivers seat....
McKrevice
01-16-10 05:56 PM
