VSC / Engine check lights after work on car
Helo,
I read a lot of posts about the VSC / engine check lights which are lighting on the dash. But I have a particular question:
I changed the cam belt and the wheels, after that everything was ok. But after 4-5 miles the signs started to light. I disconnected the battery, solved the problem...but after 3 miles...the same.
What could this be???
Thnx in advance
Thnx in advance
Have the OBDII codes read.
Cam belt? Would that be the timing belt [main pulley, two cams, water pump]
Your could be off by a tooth or two. There may be some other issues as well, so a read of codes is a must.
Salim
Salim
Thnx. I went to the dealer and it was: P1346.
They said it could be a sensor problem or the timing isn't right...si I think we have to do the job over again :-((((
first check:
Check your timing marks before releasing tensioner.
Check your timing marks after releasing your tensioner.
Crank the main pulley with hand (2 or 4 or 8 turns) and recheck the timing marks [Match marks on the belt will not match, but the cams and the main must match].
Now dont feel too bad as the tilt in the VVT can make timing belt little awkward. Remember to keep the slack on the tensioner side.
Salim
Juelz21
12-05-17 08:23 AM
boatable
06-03-15 11:24 AM
