Coil Pack Wire Torx Bolt Size
Hello Everyone, I tried to search but couldn't find the answer, so I hope you can help. What is the Torx Socket Size for the 2 bolts holding the coil pack wire?
It's a E5 or E6. I remember I drove around trying to find one last summer and ended up just using a pair of vise grips to break the bolt loose.
It' E6 but prepare for the shear-off. TOYOTA use steel bolts on aluminum alloy(valve cover), the result:TROUBLE!!
I grind the head of bolt to square and use a adjustable wrench to get it off.(vise grip didn't have enough grip)
I put a 6mm bolt with 10mm head back,it's much easier for next time to remove it. I really don't understand why TOYOTA do that ?? Can anybody enlight me ?
Please let me know your outcome. I'm going to change my water pump this spring, if the shear-off is so frequent, I'll jack up engine and use stud remover. Please info. me whenever you're done. Thanks.
If memory serves me correctly, I believe they were the same bolts on both the valve cover and the coil pack.
joshoowa
Suspension and Brakes
35
04-30-05 09:41 AM
Caanon
Performance & Maintenance
11-14-04 09:05 PM
