Is this normal for the radio antenna?
I just got a used 2001 Lexus RX300 with NAV. I used to have a 2000 Lexus RX300 (obviously w/o Nav). Anyways, on the 2000, the antenna would go up only when I wanted to listen to the radio. When I would listen to a CD or tape, the antenna would either retract or not extend (as the case may be depending on its prior position).
However, on the 2001, the antenna extends no matter what function is being used -- radio, tape, or CD. It only retracts when turning off the audio system or turning off the vehicle.
Is this normal or is there a short/miswire somewhere?
Thanks for any info.
Out of Warranty
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Might prevent ejecting a cassette, defaulting back to previous radio selection and extending the antenna - in a carwash! That lesson cost me $120.
I have a 2001 Silversport and my antenna only goes up when I use the radio. If I am playing the CD (which is most of the time), the antenna stays down.
Would this be part of the "C-BEST" programming feature the RX has?
Out of Warranty
![Arrow](https://www.clublexus.com/forums/images/icons/icon2.gif)
Yeah, Doc, my bad! Unfortunately mine's a plowhorse, not a show pony.... At least it's "golden pearl" and the scratches don't show. Actually, I suspect the atmosphere down here is more corrosive than the commercial solvents! I usually have it hand-washed before picking up a client, with a quick rinse about twice a week during pollen season. You gotta love Lexus' paint, it stands up to a lot of punishment and still polishes up like new!
I just had to learn to keep my fingers off that radio button during routine exfoliation!![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Cbest - Mine's a 2000, and if you turn the radio on, the antenna extends. If you then select tape or CD, the device starts playing and the antenna retracts. I got in trouble at this point by ejecting the cassette, which defaulted back to "radio" and extended the antenna again. Evidently I'm not the first to do this - they fixed that little idiosyncrasy by 2001.
![Thumbs down](https://www.clublexus.com/forums/images/icons/icon13.gif)
My 2001 RX300 with NAV does the same thing. It's a pain in that I have to remember to turn
the CD player off before I drive into the garage because the top of the antenna hits the raised door.
Just found out why the antenna stays up from my service rep. This is apparently normal in vehicles with the NAV system because the audio system on these vehicles have R.D.S. radio reception which receives emergency radio broadcasts. These broadcasts will override any audio function when the audio system is on, and the antenna has to be up to receive these broadcasts.
Salim
joetifosi
RX - 1st Gen (1999-2003)
12-26-17 07:22 AM
