Instrument Cluster Drive Gear Indicator Light Out
Old 06-07-11, 12:15 AM
  #151
OzrkFisher
OzrkFisher's Avatar
Am I the only the one whi is just going to live with it ?? Brian
Old 06-07-11, 03:38 AM
  #152
hypervish
hypervish's Avatar
No, im going to live with it too, I have on all of my other Toyota/Lexus cars so why not this one! hahah
Old 06-07-11, 05:06 AM
  #153
Lexmex
Super Moderator
Lexmex's Avatar
I've lived with the bulb out for a long time...have no issue with it.
Old 06-07-11, 05:31 AM
  #154
iolmaster
iolmaster's Avatar
Been driving a 2000 since 2005 with it out. I don't miss it. It is actually kind of nice at night.
Old 06-07-11, 07:25 AM
  #155
Raoul
Raoul's Avatar
My wife has never noticed it was out.
She relies on the gearshift itself.
However, it hit the fan when the gearshift light went out. At night she couldn't tell what she was shifting to.
I had to fix that one pronto and it was easy.
Since the dash light is redundant and she never looks at the dash anyway I can sleep well at night without the fix.
She literally never looks at the dash.
Last weekend I had a wheel off looking for a slow leak.
When I was done I inadvertently left the Parking Brake engaged.
Later I hear her backing out of the garage with an awful squeal and I had to run down the driveway waving my arms to stop her.
My BMW is a stick and I use the Parking Brake often.
She doesn't drive it much but the brake is toast anyways.
Barely holds on the last click.
I mean she never looks at the dash.
If you see an RX driving with its blinker on that's just my wife, going around the World to the left.
CBJTexas13 (09-06-23)
Old 06-07-11, 08:38 AM
  #156
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
Keep on reminding her, (and any one else you introduce to driving) that it is imperative that when you move the key first time to run or ON (before start) to wait and check the instrument cluster. This is the self test position of all warnings. After start recheck the cluster to see run position of the gauges (do this while putting on seat belts).
Glancing at hem occasionally is also good, but that one may be harder to adopt. I rented a Toyota Yaris (the cluster is in the middle). That was the time I realized that I am a habitual occasional glance at the instrument cluster driver.
Salim
Old 06-07-11, 08:57 AM
  #157
Raoul
Raoul's Avatar
Originally Posted by salimshah
Keep on reminding her...
We've been married 34 years, its too late for all that.
The upside is, her dash cluster is the perfect place to keep my wallet and pictures of my girlfriend.
Old 06-12-11, 05:33 PM
  #158
jbl-1985
jbl-1985's Avatar
It's a little involved to replace that thing, as people have noted here. I replaced mine last March (2010) and it just went out last week again.
My solution this time is to not bother with it. If it only lasts that long, it isn't worth going in there and replacing it every year for my time.
Old 06-15-11, 03:28 AM
  #159
Stemmer
Stemmer's Avatar
Default Drive indicator and rear tail lamp
'99 RX300, drive indicator bulb out for years. Amazing how common it is. Does not really bother me at all and no plans to replace it. Did just pay a Lexus dealer $40 to replace the high rear tail lamp bulb as that indicator did annoy me and after buying a $2 bulb for a DIY, decided the cover was too tricky and did not want to end up breaking it. So let dealer do it, wash and vacuum and gorged on cookies and soda while watching ESPN in the lounge. Not the worst decision ever.
Old 12-02-11, 07:50 PM
  #160
karasdad
karasdad's Avatar
Toyota P/N 83119-24670
picked one up today for $8.11 plus tax at Lexus of Bellevue, Bellevue, WA
Replaced it a couple of years ago at 75K and it went out again at 100K
Old 01-19-12, 11:04 PM
  #161
wing0
wing0's Avatar
Originally Posted by 00LexusRX
I got a set of 5 incandescent bulbs with the base that works with the RX dash. The cost is $1.00 and shipping/handling is $7 from All Electronics. I order a lot of electronic parts from this source, they are reliable. With the time savings and the price of gas not a bad deal....
http://www.allelectronics.com/make-a...SE-LAMP/1.html
Mine just went out.
Is this the same brightness as the OEM one?
I wonder if there is an Neo LED with 10mm base and 12mm height...
Old 01-19-12, 11:11 PM
  #162
wing0
wing0's Avatar
Actually...just found this
http://www.superbrightleds.com/cgi-b...pecs%2FNEO.htm
From the diagrams on the bottom, it looks like neo4-x has the right base diameter and height, and the diameter of the bulb is 4mm too.
The only drawback is they don't have white color.
Old 01-19-12, 11:40 PM
  #163
wing0
wing0's Avatar
Found one more.
http://www.ebay.ca/itm/2pcs-T3-T4-T5...item2ebacdadeb
Honda uses the same type of bulbs in their HVAC controls in ridgeline and odyssey so there are threads on this.
For those who replace the bulb already. Do you remember if the bulb height is crucial in the fitment or there is a bit more room than the 12mm specified by the neo wedge T4 spec?
Old 02-23-12, 01:44 PM
  #164
bigvito
bigvito's Avatar
Did the repair today. Very easy. Takes about 10-15 minutes. I didn't unhook anything. Just moved it out of the way. Also replaced the light on the shifter console. That took about 5 minutes. Very easy also.
Old 12-03-12, 12:04 PM
  #165
meffaman
meffaman's Avatar
Originally Posted by rmwest
I know this is a very old thread, but light bulbs continue to burn out.
I am in great debt to those who have made the previous excellent postings, but have my own additional comments and suggestions after having done the thing myself.
When removing the two "trim pieces" and the black trim piece surrounding the instrument cluster, please be advised that the metal clips may break, pop out (and become lost), or become bent and unusable. So, it may be a good idea to purchase 3-5 of these in advance (appx. $.50 apiece), before you begin this project. I lost and/or distended three clips in the process, one from each trim piece. You don't want to put it back together without the right clips in place, otherwise rattles will likely occur.
When removing the black trim piece surrounding the instrument cluster, you should disconnect the electrical connector on the left hand side before attempting to pull the piece out. There is a small tab on the top of the white electical connector. By pushing down on the tab and pulling out (rearwardly)at the same time, the plug should be removable from the socket.
I did not pull the three electrical connector plugs out from the rear side of the instrument cluster. An earlier post stated that by rotating the cluster into the right position, the dreaded "D" bulb can be removed and replaced. This is true, but don't try it with the "P" (for park) bulb. You can't get to it. If you want to replace all of the bulbs, you will have to pull the three connector plugs out. They are not a piece of cake to pull out, unless you have very skilled hands and eyes that can peer over the back side when pulling.
Lastly, the plastic of the base of the bulbs I purchase was rather "soft". As a consequence, when screwing in the replacement bulb(s), be careful not to strip the groove into which the screwdriver blade is inserted. Get a screwdriver that has a blade very close to the dimension of the groove/slit in the base of the bulb. Make sure the bulb in securely seated. Otherwise, you'll be doing it all again. Not fun.
Good luck,
Owner of 1999 RX-300 (REXY)
Does anyone know the part number of the little metal clips that pop off? I'm planning to take off some interior pieces and want to have some on-hand.
Quick Reply: Instrument Cluster Drive Gear Indicator Light Out
