Instrument Cluster Drive Gear Indicator Light Out
Old 12-28-12, 04:33 PM
  #166
joetran
joetran's Avatar
Originally Posted by cduluk
Just for future reference:
The P bulb is under the white. Don't start 3 down from R :P
In this picture have 5 bulbs but have P,N,R,D,2 and L. Today I fix D but bulb P does not light ? Help me. Thanks
Old 12-28-12, 06:18 PM
  #167
joetran
joetran's Avatar
I found auto headlight bulb does not light . How for change it ? What is part number ?
Thanks
Attached Thumbnails Instrument Cluster Drive Gear Indicator Light Out-18982104.jpg
Old 03-09-13, 05:16 PM
  #168
shumif1
shumif1's Avatar
any LED replacements for the ones that light up the speedo, tach, temp and fuel ones. i looked at the back of my cluster and those seemed to be a totally different bulb, they look like a metal housing for those bulbs.
Old 05-16-13, 03:28 PM
  #169
JZS147btr
JZS147btr's Avatar
+1 for great info! Has anyone tried the LED bulbs yet? I would imagine that they would last a LOT longer...
Old 10-20-13, 07:06 PM
  #170
BBLexus
BBLexus's Avatar
Great DIY instructions from the OP! Did this today and everything went well without trouble. NOTE-I highly recommend that you get an interior trim / molding tool kit from your local auto parts store if you don't have one. This makes removing trim easy and not damaging the trim pieces a must.
Old 10-30-13, 04:56 PM
  #171
SpaCovers
SpaCovers's Avatar
The other bulbs were stated earlier in this post as being #74 from the auto parts store but those were a little fat and didn't look like they'd fit into the bulb holder. O'Reilly's had slightly thinner bulbs #2721 ($5 for a 2 pack) which also said "Replaces 17037". The part number at the dealer without the holder: 9098111018 ($5.19 each). The bulbs so come out of these tiny holders by trying to pry them while pulling at the same time.
FYI: These bulbs, which mine has about 24 on the back of the cluster (I'm eating and don't want to count again), also fit the bulb for the shifter position indicator light in the center console.
FYI#2: The bulbs for the joint lighter and ignition are the same: 8499910250. These are bulbs attached to a harness.
Old 06-01-14, 11:09 PM
  #172
iamhere9
iamhere9's Avatar
Originally Posted by 00LexusRX
I got a set of 5 incandescent bulbs with the base that works with the RX dash. The cost is $1.00 and shipping/handling is $7 from All Electronics. I order a lot of electronic parts from this source, they are reliable. With the time savings and the price of gas not a bad deal....
http://www.allelectronics.com/make-a...SE-LAMP/1.html
Do you know if they have bulb and socket for ABS indicator ?
Old 06-02-14, 09:08 AM
  #173
Anseladam
Anseladam's Avatar
First time here.
Just picked up a 1999 RX300, 144K on the ODO. Test drove it really liked it.
My better half gets in the driver's seat to test drive. FIRST thing she mentions is the D light is out. I hadn't noticed it as I was too busy listening to the engine/trans.
I think I'll live with it being out.
Old 10-30-15, 10:21 PM
  #174
fatlouis
fatlouis's Avatar
Default got it done!
thank you all for the clear instructions. ironically, the local lexus dealer priced the bulb $1 cheaper than the Toyota dealer across the highway. I wasn't paying attention and took off the circuit board attached to the main circuit board...this is unnecessary as the bulbs responsible for lighting the gear indicators are at the bottom of the main board, unobstructed by the second circuit board. Anyway be careful inserting the new bulb...the plastic is very soft and you do not want to end up with a stripped screw. I was not able to detach the left most plug (there are three that connect the cluster to the wiring loom), but the cable was long enough that I could do the swap by placing the cluster upside down on the dashboard. again, you will need a soft towel to make sure the clear plastic cover does not get scratched.
Old 10-31-15, 02:55 AM
  #175
toyo
toyo's Avatar
This is a awesome company for buying those bulbs.
http://www.oznium.com/
Old 01-21-16, 08:36 AM
  #176
yuyangbit
yuyangbit's Avatar
With all your great help, I switched the bulbs of "D" and “2” . The local dealer (Edmonton, Canada) gave me a wrong part and I really do not feel like to drive 15 km to return a 6 CAD bulb.
My RX300 is 2002 with 180K (km not miles) and I found that the cluster top two screws are a little tight due to its age.I switched a few screws drivers before able to apply my force correctly without hurting the screw.
Be patient to unplug the cables, you never want to repair the old cables if you broke any of them.
There are a few metal clips of covers and cluster might fell down from their holder during the repair, pay attention to the clip number as we all want the job can be done flawless.
It is my 0.02
Old 01-21-16, 08:46 AM
  #177
wing0
wing0's Avatar
My RX300 is 2002 with 180K (km not miles) and I found that the cluster top two screws are a little tight due to its age.I switched a few screws before able to apply my force correctly without hurting the screw.
It is my 0.02
did you give them this part number? 83119-24670
Old 01-21-16, 09:14 AM
  #178
yuyangbit
yuyangbit's Avatar
Of course, I gave the correct P/N. They gave me a 00234-00192。。。。。
Old 01-21-16, 09:55 AM
  #179
wing0
wing0's Avatar
Of course, I gave the correct P/N. They gave me a 0024-00192。。。。。
If you clearly gave them that, I would talk with their parts manager or even dealership manager and demand that they mail you the new bulb part without you driving in.
Old 02-24-16, 04:10 PM
  #180
Xtom73G
Xtom73G's Avatar
I may get into this project soon, and at the same time, I wish I could replace the white instrument needles with red ones. I could not seem to find any solution, especially a brainstorm lighted needle, like on my wife's ES300. Any solutions or ideas?
Quick Reply: Instrument Cluster Drive Gear Indicator Light Out
