Suggestions for other repairs while doing CV Axle
So I now have to do the front CV axles. While I'm taking everything apart, I plan to do the following:
lower control arms
ball joint
outer tie rod end.
wheel bearing
I'm considering:
inner tie rod
sway bar bushings
How difficult is it to do the inner tie rod & sway bar bushings?
Is there anything else that will be exposed during this job that will probably need to be done?
Is there an aftermarket brand recommended for the wheel bearings?
Does anyone know the Toyota part # for any of the parts listed? I see on the forums that the Lexus shares the same lower control arm as the '98 Camry. Does anyone have part # for comparable parts for other items?
Thanks!
lower control arms
ball joint
outer tie rod end.
wheel bearing
I'm considering:
inner tie rod
sway bar bushings
Thanks!
Add transmission output seals.
Salim
Salim
I can't seem to find a wheel seal for the fronts. Do you have a part #?
It can be a big PITA if you don't have a press available. Call your local machine shop for pricing of pressing/installing your bearing. In the past, i've been charged as little as $25 per hub on other cars i've had.
FWIW, autozone has free loaner seal drivers and bearing pullers available that might work if you want to tackle it yourself.
Edit: Just came across the DIY thread . The front uses an oil seal and snap ring.
https://www.clublexus.com/forums/sc-...placement.html
Thanks everyone for the advice. Has anyone ever done their inner tie rods? Cheapest I can find are $80 a pop and I'm starting to break the bank.
Salim: the transmission output seals - I presume these are where the CV axle enters the transmission?
Fastnoypi: I decided to just buy the assemblies. I live out in the boonies and it's difficult to get anywhere without wheels under me. Thanks for the link, that got me looking at the schematics again.
I wonder how many big baby crocodile tears this job will squeeze out of me. lol
Read my DIY on boot repair. Skip the details but follow the checks.
You must lay the old and the new shafts side by side to ensure they are of the right length. Protect your threads at all times (I usually put the nuts on the threads to protect them). Never stretch the shaft and when you pick it up, lift from both sides [if you pick from one end, you will stretch it out]
Exercise caution and do one side at one time (keep three wheels on the ground at all times). Do not force anything and you will need a high range torque wrench and large socket.
Salim
Salim
Tony55330
Suspension and Brakes
01-20-23 05:41 PM
2GSTony
12-09-14 10:29 AM
DosyBoy
05-30-13 02:52 PM
