Extra transmission oil cooler: Y or N?
Old 04-22-15, 12:46 PM
nipponbird
nipponbird's Avatar
Originally Posted by Comity
I can't say it does any harm at this point, and I don't think it delays the initial warm-up to any great extent as I haven't noticed it staying in a lower gear when I first start out driving. Also, I haven't seen any indication of engine temp running higher than it should (always stays dead center of the temp gauge) due to blocking the radiator air flow.
Yes, the install does look sloppy and bothers me to some extent, so I will probably just clean up the install and leave it on. Since I am getting ready to replace the metal lines below it that have really rusted and do the full change-out of fluid, I will get new trans hoses of the correct length.
Thanks to all for helping me think through this.....much appreciated.
It's clear that you've made your mind up and I don't say this for you to reopen the case, but I've played a lot with oil coolers on Corvair engines, which I've installed in VW bugs. First of all keep in mind that an oil cooler needs an oil thermostat valve to open at a given temperature, unless you have an oil temperature gauge installed in the oil gallery, you won't know what time it takes for the oil to warm up with a slapped on oil cooler. If you run the engine at lower oil temperatures than it was designed for, you'll accelerate wear in that engine. Factory installed oil coolers all have an oil temperature thermostat (mostly installed where the oil leaves the engine enroute to the oil cooler to isolate the cooler while the oil is below a certain temperature), which is nothing else than a plunger and spring that is of course temperature sensitive.
Furthermore: make very, very sure that the oil lines to an oil cooler cannot rupture. You will lose the oil in the engine in about 20 seconds flat if that happens and if you don't switch the engine off in time, look forward to a complete rebuild.
Old 04-22-15, 01:05 PM
fastnoypi
fastnoypi's Avatar
The OP is discussing a cooler for his transmission, a thermostat is typically not needed.
You are correct that you need a thermostat for an external oil cooler for an engine.
Old 04-23-15, 12:11 AM
nipponbird
nipponbird's Avatar
Thanks for pointing it out, but I'm aware of the OP's needs. What goes for an engine oil cooler usually (pay attention to the "ususally") goes for a tranny oil cooler too.
I would like to know why you say a thermostat is not needed for a transmission oil cooler as it is the opposite in most cases.
The set-up the OP now has, is fluid which has already had a temperature drop from the stock oil cooler. There is little room for the man in the street to determine scientifically at what temperature the fluid re-enters the tranny from his aftermarket cooler. Of course it is now at a lower temperature than when it should've only the stock cooler to negotiate. Thus the tranny must reheat it to operate at the desired temperature on which the designers have decided, which can affect a lot of factors calculated by the tranny's ECU.
My point is: bin it, it is probably counter productive.
Old 04-23-15, 04:24 AM
fastnoypi
fastnoypi's Avatar
The thermostat bypass is typically not needed in a transmission cooler situation because usually the setup is in loop and temp regulated by the ATF reservoir tank integrated in most automatic transmission radiators. Normal operating temperature of ATF is between 150-200F . Each 20* increase above 200F significantly breaks down the ATF protection and reduces longevity.
Fwiw, the coolant side of an automatic transmission radiator or any radiator tries to regulate temps between 180F minimal and 220F before fans kick on.
Old 04-24-15, 05:57 AM
hayafalcon
hayafalcon's Avatar
I hope you just left the aftermarket cooler in place, It can't hurt anything and likely will help keep the trans and front diff cooler and that's always a good thing. One tip if you are concerned about the cooler suddenly springing a leak.....just collect an adequate length of rubber hose and a few clamps and a screw driver. Keep them in the car. Now your covered. If it leaks you can bypass it on the fly in about 10 min. Same goes for the original cooler. I had mine start leaking really bad while in town. I was able to find a hose and clamps at a Reilly's and bypassed the cooler til I got home. Turns out it was just the stub end on the cooler outlet. The little pipe was cracked. I removed the bypass and I just pushed the outlet hose on farther and reclamped it. That was 3-4 years ago and still holding. Haya...
nsx042003
05-31-16 11:36 AM
BillitZky
GX - 1st Gen (2003-2009)
04-03-16 04:21 PM
JasonARGY
11-18-15 06:36 PM
Doco21
06-02-09 06:50 PM
vu0219
02-10-08 11:38 AM
Quick Reply: Extra transmission oil cooler: Y or N?
