Windows
Registered User
Does the RX300 have a feature for the windows which allows you to open and close the windows via the remote or by putting the key in the driverside door lock and turn and hold to open or close the windows and sunroof? Thank You
Can you explain how the feature works. Does it close all the windows when you push the lock button on the remote?
You can open all the windows and sunroof remotely.
Press the open button on your key for a few seconds.
You can also insert the key in the door, turn it to open
position and holding it there for a few seconds.
You can close them all at once by inserting the key in the door,
turning it to lock position and holding it there for a few seconds.
The remote will not close them all. As I said, You can close
them all at once by inserting the key in the door, turning it to
