Battery dying
Battery dying
I recently purchased a used 2000 rx300. At the dealership it started no problem. On two occasions. But when I brought it home and let it sit overnight it doesn't crank. At first I thought it drained because the radio was still on. Turned that off. Problem persist. Then the display stayed on, but when I put the ignition switch in the lock position that fixed the problem.
I'm at a loss. When I boost off the battery it runs just fine but I can't keep doing that.
Thoughts or suggestions?
bring the battery to a parts store. Alot of them including Walmart will do a deep cycle battery test for little money or free. If it checks out fine, then you may have alternator, starter or cable problems.
Salim
