RX 300 A/C filter
Welcome to ClubLexus,
The part you seek is:
Interior cabin a/c filter 87139-48020
These are available at almost any Lexus or Toyota dealer. Call their parts department with the number above.
or you can order them online through www.irontoad.com
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
If you want to find the one you have, look in the glove box. The back of the glove box has a removable piece about 2 inches wide and 10 inches long, it pops out - kind of slides up and pull it out. Use of a flash light here helps a lot.
Once the back piece is out, look in and you will see a panel about the same size that will pull off. The use of a pair of plyers here also helps out a lot. Then you will see the edge of the filter tray. Pull it out with the plyers.
Now, for loads of info on where to find a new one or roll your own, use the really excellent search engine on this site. Good luck!
