P1305 code
Old 09-23-15, 09:35 AM
tbirch
tbirch's Avatar
Default P1305 code
I have an 2000 RX 300 I have the code P1305 I have replaced all 6 ignition coils and spark plugs. The car is bucking and loosing power it also has multiple misfires. My mechanic says it is the ECM. Has anyone else had the code/problem?
Old 09-23-15, 11:56 AM
jdbrx300
jdbrx300's Avatar
dont throw parts at it. waste of money. have qualified technician diagnose it. A p1305 is a No. 2 Igniter Circuit Malfunction.
Old 09-23-15, 11:58 AM
jdbrx300
jdbrx300's Avatar
a bad ecm is hard to diagnose.
Old 09-23-15, 12:00 PM
maxSteel
maxSteel's Avatar
Was that the original code before you started changing parts?
Any other codes now, other than misfires?
Old 04-18-18, 01:36 PM
Wallyrx300
Wallyrx300's Avatar
I have this code currently. i also had codes for the coil p0302 i replaceed the coil and the plug. i tested on other coil packs to make sure they coil was bad. REplaced, but still getting p1305. I am assuiming that the ECM is bad. Does anyone have a location or removal instructions for the ECM?
Old 04-18-18, 01:37 PM
Wallyrx300
Wallyrx300's Avatar
Default p
i waas told that there is nothing bewtween the coil and the ecm, so what else could it be if not the ecm?
Old 04-18-18, 02:00 PM
Wallyrx300
Wallyrx300's Avatar
Default p1305/ replaced # coil and plug
replaced and cleared codes. I cross tested new coil and #4 coil stll getting a miss fire. I know the RX300 is know to have ECM problems. I have found several places that rebuild and reprogram. Does any one have a removal procedure or any other possibilities?
Old 04-18-18, 05:50 PM
salimshah
salimshah's Avatar
Received 1,071 Likes on 964 Posts
Not sure what lead you to think the ECM of RX is down to have problems. Over the years, I have not seen any one report ECU problems. Even if one or two did, it would be statistically very small number.
Check for pinched wires.
Salim
Old 04-19-18, 04:56 AM
Wallyrx300
Wallyrx300's Avatar
Salim
I have found that this 1st gen has many issues with the ECM going bad and needing to be refurbished. The processors lag and go bad. I called lexus to price the part and the also stated they had many issues with the ecm's having to be replaced on the 1st gen. Do you know the location of the ecm and how to remove so i can mail it in for a reprogram/refurbish?
Old 04-19-18, 08:45 AM
fastnoypi
fastnoypi's Avatar
https://www.autozone.com/repairguide...96b43f81b3cac1
you can get a salvage ECM for less than 200 on car-part.com however, i also think it is rare for an ecm problem. I'd check your ignition harnesses for any possible damage. Rodents can cause havoc on wiring.
jatf
08-02-24 10:05 AM
bwhitsonjr
02-19-19 04:29 PM
AnthonyMtz
03-20-15 12:25 PM
2gs300
12-13-14 07:30 AM
dlpalmer20
Maintenance
11-08-09 12:51 PM
Quick Reply: P1305 code
