no heat
i have no heat i have checked servos and they are working can see them moving the arms and both pipes are hot on heater core is it possible the door came off or can there be a clogged core
thanks for any help
thanks for any help
Start by checking coolant level.
Engine cold and and radiator cold to touch. Uncap the radiator and peer inside. Coolant should be all the way up.
Salim
Salim
If hot coolant is making it from the core inlet to the outlet it would seem to imply the core isn't clogged.
When you say "No heat" is there good air flow?
Is the air mix servo actuating the damper?
yes fan blows all servos working disconected arm for temp door and hand moved still no heat was looking at the arm was wondering if there is supposed to be a screw in there
Once the servo has been removed you can manually move the damper. Just make sure when you reattach the servo arm matches the damper position. (write down the current position).
Salim
Salim
jasepb
04-11-19 03:07 PM
