Towing pkg
Old 01-18-16, 08:36 AM
tonyjh63
tonyjh63's Avatar
Default Towing pkg
I've read somewhere that the 4th digit in the VIN indicates whether or not the car in question is equipped with the factory towing package - that if the 4th digit is "H", then it has the towing package. Is this correct? What if it doesn't have a trailer hitch? Does this mean that it has the transmission cooler, and is pre-wired for towing, but just doesn't have the hitch installed yet?
Also, if all this is correct, does this apply to the other RX models as well?
Thanks for any information...
Old 01-18-16, 08:44 AM
salimshah
salimshah's Avatar
Received 1,097 Likes on 987 Posts
Even within first gen of RX300, there are differences in harnesses. I would only trust Lexus parts counter to dig the information you are looking for. Internet at times is not the best (most reliable) source of information.
Are you seriously looking to tow? And how much weight? I would recommend light load and rare use of towing. Well maybe more than a few times if you have AWD.
Salim
Old 01-18-16, 09:39 AM
maxSteel
maxSteel's Avatar
According to this the 4th digit is the body type, where H is a 4 door sport utility 4x4.
http://www.vehicleidentificationnumb...lexus-car.html
According to my window sticker mine came with the "towing prep package and transmission cooler". I don't seem to have the connector for the trailer wiring and it didn't come with the hitch. I used aftermarket for both.
Old 01-21-16, 04:31 PM
sktn77a
sktn77a's Avatar
The towing package consisted of the aforementioned transmission cooler and body/trunk wiring harness/isolator module. The short wiring harness from the trunk to the hitch and the hitch itself were port-installed options.
Given the history with the early RX300s' transmission issues, towing the specified 3500 lbs is not recommended.
tfherbert
Hybrid Technology
20
05-24-18 08:19 AM
ahild96
04-11-17 02:47 AM
CanadianRX
RX - 3rd Gen (2010-2015)
08-26-16 08:33 PM
ShakMan
05-26-04 09:51 PM
RandyL712
04-04-03 10:39 AM
Quick Reply: Towing pkg
