Does the A/C need to be discharged to switch out the radiator?
I need to pull the radiator out to replace. The manual states to discharge the A/C, but it also pulls the condenser and everything else out as part of a strip down. Does it actually need to be discharged or can the lines simply be unbolted and the radiator lifted out?
My understanding is Yes! So plan for it and if you figure out a way, please post.
Salim
Salim
Well, there are only two ways to do it that I can think of: crack something open and let it seep out or take it someplace and have them discharge it with a machine.
I think taking the condenser out would make the job a lot easier, but I'm not sure it needs to come out. I'm hoping it will just take a few loose nuts/bolts to get it loose and I can leave everything connected in that system.
I will definitely report back and probably make up a tutorial at some time. If anyone has done this and can give any advice before start, please let me know.
Everyone rejoice! Radiator can come out without pulling the condenser. Brace yourselves for a very poorly written, barely photographed tear-down and (hopefully) re-assembly.
Great, glad to hear! I'm not a fan of messing around with A/C components, best to leave that to the professionals who have the right equipment. Looking forward to the DIY!
Looking forward to your documentation. I hate having to recharge an A/C system just to work on other things. Hopefully you were able to loosen components enough to be able to slip out your radiator. Knock on wood, no issues yet with my original 150k+ mile radiator. There is a DIY youtube vid for radiator removal from a toyota sienna. Can you comment on any differences? The layout looks very similar, if not identical to our 1st gen RX's. .Here's a link to the vid.
I did the radiator on my 1998 Toyota Sienna and it was a piece of cake, 15 minutes coming out & 15 minutes going back in. I think the setup is different than the RX, although admittedly I haven't looked at how the radiator is installed in the RX since it has a black cover on top which i haven't had the need to take off yet. I remember another CL member had to take the front bumper off on the RX to get to the radiator, perhaps that's because he also replaced the A/C condenser.
Fastnoypi: It's a bit different because of the framing, which is what makes it difficult. Some tubes are a bit different, otherwise it looks very similar. I wish it was that much room in the RX.
Hypervish: Without actually removing the condenser, I can't say for certain, but based on visuals, I think you might be able to get it out without removing the bumper. It would be tight getting to the necessary bolts, but I hate taking parts off so I would probably try that first.
thaeleelyr
RX - 1st Gen (1999-2003)
35
12-21-22 06:09 AM
pmpdaddyt
Performance & Maintenance
11-01-08 04:26 PM
