Need Wheel Offset advice
Hi everyone, thanks in advance for your suggestion.
I have a 2002 RX300 and purchased a set of used tire today without too much thinking.........
The tire size is 235 70 R16 and the rim size is 16*7. However when I measured the center hub size and wheel offset after I returned home the center hub size is 72 mm (60.1mm original) and the wheel offset is 42mm (35mm? original) .
A hub centric ring can solve the hub size problem but I am not sure if the wheel offset could give me extra trouble.
Benjamin T
Wheels, Tires & Brakes Forum
12
07-16-07 05:27 PM
hiyabrad
01-26-03 10:35 AM
