Wrong O2 sensor???
Old 03-07-16, 08:55 AM
matthewlsw
matthewlsw's Avatar
Unhappy Wrong O2 sensor???
2003 RX300. Got the trouble code for the Heated O2 Sensor (Bank 1 Sensor 2). Lexuspartsnow.com says I need part number
89465-49075
http://www.lexuspartsnow.com/parts/l...465-49075.html
I believe them so I bought the same exact part from Amazon even though their site says it doesn't fit, thinking the Lexus site will know better.
Amazon.com: Toyota 89465-49075 Oxygen Sensor: Automotive Amazon.com: Toyota 89465-49075 Oxygen Sensor: Automotive
Got it installed fine and cleared the codes but the code keeps coming up every time I clear it. Did I just waste $140? Why would one site list it as fitting and the other doesn't? Could it potentially be another issue?
Old 03-07-16, 09:07 AM
fastnoypi
fastnoypi's Avatar
welcome..what was the exact code or list of codes when you had the original CEL showing up?
Old 03-07-16, 09:21 AM
matthewlsw
matthewlsw's Avatar
I will have to go grab the code again at lunch, but my device said "Heated Oxygen Sensor Bank 1 Sensor 2" and that was the only trouble code
Old 03-07-16, 09:31 AM
fastnoypi
fastnoypi's Avatar
some codes that come up could be false positives especially if there are multiple codes displayed. However, there might be a problem with your B1 catalytic converter. Are you experiencing oil consumption? If so, runners off the rear manifold flow to the B1 catalyitic and unburnt oil might be clogging it.
I would first try a long sustained drive to get the catalytic converters nice and hot and see if the code clears itself.
Old 03-07-16, 09:43 AM
matthewlsw
matthewlsw's Avatar
Ok I will try going on an hour drive sometime soon. And just because I forgot to mention it, the check engine and VSC lights are on
Old 03-07-16, 01:10 PM
matthewlsw
matthewlsw's Avatar
Another thought: do you think it could be the circuit back to the ECU causing the issue? And if so, how could I check it?
Also, I'm attaching a photo with the exact trouble code
Old 03-07-16, 01:49 PM
fastnoypi
fastnoypi's Avatar
you should have posted the code to begin with. p0155 is bank 2 sensor 1. You bought the wrong o2 sensor. It calls for the type before the catalytic converter.
Old 03-07-16, 02:09 PM
matthewlsw
matthewlsw's Avatar
This diagram shows it has bank 1 sensor 2
I got it from this thread https://www.clublexus.com/forums/rx-...el-sensor.html
And this is where I found the part number for it http://www.lexuspartsnow.com/parts-l...rs=89465-49075
Old 03-07-16, 02:22 PM
fastnoypi
fastnoypi's Avatar
let me get back to you, i will verify my manual for location. in either case it should be pointed to an O2 sensor pre-cat.
Edit: OBD2 report codes are standard. p0155 is universally bank2 sensor 1. Top of your front manifold.
Old 03-07-16, 08:10 PM
carguy07
carguy07's Avatar
This worked perfect for me:
Amazon.com: Denso 234-4215 Oxygen Sensor: Automotive Amazon.com: Denso 234-4215 Oxygen Sensor: Automotive
Old 03-07-16, 09:29 PM
salimshah
salimshah's Avatar
Received 1,097 Likes on 987 Posts
The attached pic should only show Sensor 2 [there is no bank implication as it is after the Y].
Salim
Old 03-08-16, 04:04 AM
carguy07
carguy07's Avatar
This
Old 03-08-16, 07:30 AM
rosen71
rosen71's Avatar
I got 2 of these.
Both error codes were gone after replacement.
Amazon.com: Denso 234-9009 Oxygen Sensor: Automotive Amazon.com: Denso 234-9009 Oxygen Sensor: Automotive
Old 03-08-16, 07:41 AM
fastnoypi
fastnoypi's Avatar
Originally Posted by rosen71
I got 2 of these.
pre-cat o2 sensors for b1s1 and b2s1
Old 03-08-16, 08:20 AM
matthewlsw
matthewlsw's Avatar
Alright I ordered 2 of those a/f sensors. Thanks all for helping out a newbie! I'll post again with the results after they ship and I install them
Quick Reply: Wrong O2 sensor???
