blower motor
I have a issue currently with my rx. The blower motor for the hvac system is on its last leg(s) as its making a very loud noise upon initial startup of the vehicle This has been confirmed by 2 different sources. . How hard is it to change out the blower motor and is this something i may be able to tackle myself?
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/20160309_003535_3c8477eff1159a530b9562d13f235d5413c22281.jpg)
Plastic cover under passenger dash.
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/20160309_003416_a4925964d6a5515b456bb6ba826071f38779e2a0.jpg)
Simply pops right off, you might have to give it a little tug, pull from the front of it so you don't accidently break a clip.
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/1080x1920/snapchat_1730614036068849812_5ced1ef0c168c4244aac2e55e3d2d50eab983d80.jpg)
After you successfully pop off the cover you will see the blower, I tried to put this in detail on where the bolts are, don't use a Phillips head, use a proper socket and rachet.
I did get a few quotes on getting this done and the issue isnt so much the labor cost because the labor for it is pretty inexpensive; its just the part itself that is $$$$!!!! and currently i have a courtesy vehicle until me and my parents figure this out on what to do. I would attempt to do it myself but right now I just do not have the time for it as Im busy w work and such.and so because of that i may just have to bite the bullet so to speak and get it done by the dealer.
as far as I know; no. Just the motor itself i believe. and no; the part is a lot more than 50 bucks my "friend". Its in the hundreds because its not aftermarket. Its lexus oem. The labor however is very inexpensive at I believe only like 30 bucks. Its the part that is a lot more.
Pardon? If u are referring to me not knowing what is what or how to do something; well; if I feel I need to ask a ? about something then I will so please dont put it down. We are supposed to be here to HELP one another; NOT put something or someone down because of a ? they may ask. Especially for someone that may not be much of a diy er.
If you can find a dealership or garage that will charge 30 bucks for labor for this job you found yourself a unicorn. You might as well line up other jobs for them to do.
Matt you are getting more help than what you want. Dont you agree?
You can secure a used blower motor for much less than a new one. Cant say much about how long a life it would have. There are some vendors like LKQ which give warranty too.
Salim
Salim
Well, you can pay more for the OE part (about $200) but I wouldn't spend that kind of money on such an old car.
http://www.autoparts.loc8apart.com/n.../RX/Blower.php
Well; thats exactly why I wouldnt trust a used one salim. While some may not think it may be worth putting that kinda $ into such a old vehicle; I do however simply for the reason being that over here in the desert southwest; especially once its gets to about the end of april beginning of may; most people do not want to be w/o a/c either in their home(s) or their vehicle! and neither do I. I dont want to drive around in a "hot box" w/o a/c. Its more than immoral but its actually dangerous because of intense heat. nuf said.
