ABS issue
Have a abs issue with my 02 highlander.
current codes are p0136, c1201
the vsc light comes on. when i accelerate the trac control light blinks and from wheels lock up. When i press down to make a stop at low speeds, the pedal pulses and i hear a noise from the abs system.
i took out the abs relay and drove it - it runs fine . do i need to replace the abs ecu or the abs unit?
