Changing transmission fluid with high mileage
when you said i don't need any advice earlier, did you mean to not change the fluid in the differential as fastnoypi suggested? i'm unfamiliar with what the transfer case, differential and other related parts are and if they apply to both the AWD and FWD, but as long as i drain and fill, am i correct to assume that all the parts that use ATF share the same fluid and will automatically circulate?
are all the ones in the transmission filter section disposable? i see the filters but they don't specify disposable or not.
Salim
As cheap as they are, they are disposable. Plastic shell with paper filter element.
i bought a case of toyota iv yesterday but am now thinking about synthetic. what do you guys think and would it help extend the life of the transmission? and what's up with this amsoil fluid i keep hearing about... i can't find it online anywhere except maybe their own website.
thanks guys.
http://www.valvoline.com/pdf/maxlife_atf.pdf
A common belief on BITOG regarding this is that; if your transmission fails after a drain and fill, it was already on it's way out. Personally, I believe a drain and fill with new fluid is the best route to take.
Different transmissions model than your RX but I've done a Drain and fill using valvoline maxlife atf on my Gx470 (aka 4runner V8) and LS430. Those are factory filled with Toyota WS and Type IV. The valvoline is synthetic and is compatible with many vehicles including toyota brand (AISIN built transmissions). I actually did not drop the pan or change the filter but that would be ideal. I simply drained and filled the transmission pan about 2 quarts the first time then removed the transmission cooler return hose from the lower radiator and drain the remaining atf through it a few quarts at a time using this method, both vehicles had 140K miles on original ATF fluid and filters:
http://www.popularmechanics.com/cars.../a105/1272521/
Its a fairly popular way to do it on the 4runner forum . I did not change the transmission filter but that would probably be the best possible way to do this. The LS and GX/4runner/FJ/landcruiser/tacoma transmissions are known for their longevity and many make it to 200k+ miles on original atf fluids/filters. I don't think the RX transmissions are as sturdy since they are car based so I would probably drop the pan in your case for piece of mind. FYI you can buy the maxlife atf at walmart or ship it to your house on amazon for 18$ a gallon. I would also drain and fill your Power steering system using this product you will be amazed at the difference (toyota uses dextron III in their PS systems)
FWIW, i'm using Valvoline MaxLife full synthetic now in my RX300. Per the information sheet it meets Toyota/Lexus Type- T, T- III, Type-IV and WS standards and has seal conditioners for transmissions over 75k miles Can't beat the $18/gallon price at Walmart to allow frequent drain and fills or as needed.
possibly, but if you could get, for example, an extra 20-50k more out of it without touching the fluid, no one would change it!
so it seems like the debate for toyota iv vs. anything else still goes around in circles so let me ask more constructive questions:
- will synthetic fluid be better than conventional?
- will conditioners be useful or do transmissions not have leaking problems in general?
- will an expensive synthetic like amsoil offer advantages over a cheaper, but reputable alternative if do normal driving?
i think i'm currently deciding between oem toyota and valvoline maxlife. if a synthetic offers better protection and helps extend the life of the transmission, or requires less frequent changes, that's another reason for me to choose the maxlife or other synthetic. i also notice only the maxlife contains conditioners versus other synthetics but am not sure how important that is.
hsmac:
Transmission failures have not been correlated to fluid types. There is no smoking gun .. although the part that is mentioned that fails is the plenary gear system (why is unanswered).
Which fluid is better? performance/price.
My understanding is that Toyota's recommend fluid is synthetic. Please correct me if I am wrong.
At the end, do what would make you feel comfortable. The transmission fluid is not exposed to contaminates and combustion byproducts and needs to be refreshed as opposed to be replaced. It does go through stress and gets heated up as it absorbs the energy [clutch action] and the torque converter locks up at cruising speeds [fluid is not provide coupling all the time]
Salim
Salim
hsmac:
Salim
Salim
hsmac:
Salim
Salim
I believe there are other factors at play as well. Such as driver habits, ECU programming, upgraded transmissions with a smaller transmission pump then overheating fluid as a result, etc. But, won't get into those here, think we've discussed and beat this topic to death in the past.
Toyota's recommended T-IV fluid is not a synthetic, it is a conventional fluid.
In LS3some's post and to my observations in toyota truck forums where their factory fill is T-IV, T-IV breaks down alot sooner and Maxlife performs better as far as longevity and in more demanding situations that a normal commuter car would not typically endure.
T-IV is obviously factory approved and may not break down under normal driving if you do the 30k drain and fills.
There is a large community that uses MaxLife synthetic with great results too while being cheaper per quart with possibly longer change intervals possible. You can't go wrong with either.
The planetary gear set was believed to be under-designed, initially being in an aluminum carrier with only 4 gears; while some rebuild kits offer a 6 gear steel carrier. There are a ton of youtube videos with RX300 transmissions torn apart which show this failure.
under normal driving there would be virtually little or no vehicle performance benefit. The benefit of using a synthetic is in the ability to prevent viscosity breakdown.
