bolt snapped in hole... what to do?
Old 04-09-16, 06:28 PM
hsmac
hsmac's Avatar
Default bolt snapped in hole... what to do?
well..
just as i was going to warn people of how difficult/tedious it is to remove the tranny pan and put it all back given the number of bolts and limited space, one of the bolts snapped as i was torquing it down. i'm not sure what happened, but the bolt snapped near the head where the threads begin, so the majority of the screw is in the hole. thought i would try to put some super glue and try to attach the pieces but it's not catching, and neither is another bolt i removed to try to use.
no idea what to do right now. obviously can't drive the car now and the screw is pretty thin making it more difficult. already pretty frustrated from the job itself and now i have perhaps a huge problem. trying to stay positive hopefully someone can help me out with this predicament.
Old 04-09-16, 07:23 PM
carguy07
carguy07's Avatar
You might be able to get it to seal missing one bolt. That would at least make it driveable short term. I never have luck with easy outs (but some guys do). Might be able to grab it with vicegrips when the pan is removed and get it to turn. Welding a bolt to the stub would be difficult in that sensitive area. Which one was it?
Old 04-09-16, 07:51 PM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
in-lb right?
Breaking the FIPG the first time can be hard.
The fix now would likely require to separate the pan again. Some bolts pass through to the other side and you may have longer area to catch at the back side.
Worst is you may have to tap a larger size.
Salim
Old 04-09-16, 08:06 PM
hsmac
hsmac's Avatar
i'm wary about easy out too given what i've heard about them.
i was thinking that too because some gaskets only have 15 bolt holes and are supposed to be compatible. it's the one, where if you're facing the front of the car, is the second one from the front bolt on the left side of the pan (5 bolts from front to back, back being where the drain area is). so if you're facing the front of the car it's on the opposite end of the drain. looks like there's quite a bit of space in between the two adjacent bolts though, on the opposite side there are a flurry of bolts which would seem to be more secure if a bolt were not replaced.
the screw snapped maybe 1/5" inside the shaft so no way using pliers. maybe i'll try gluing something to the end again but i'm a little worried about getting glue on the shaft threads.
Old 04-09-16, 08:18 PM
hsmac
hsmac's Avatar
Originally Posted by salimshah
in-lb right?
Breaking the FIPG the first time.
Salim
yes in-lbs. seems like a rather high spec. was turning those bolts forever and after they were tight they still turned more and more. i tried criss crossing and not tightening the full amount until balancing the other side, but i was also getting frustrated with the space. thought the torque wrench might be broken but tested it on a lug nut and it clicked. also the last two wrenches i rented didn't lock for some reason (and this one was supposedly new) which made things uncomfortable, but again just having to work above with limited space and not being able to create a level angle made things awkward. again, not sure what happened but what a terrible place for a first time experience.
Old 04-09-16, 08:54 PM
sktn77a
sktn77a's Avatar
I'm guessing if the bolt snapped off, one of those reverse threaded frozen bolt removers won't have the oomph to remove it. That pretty much leaves drilling out and re-tapping.
Old 04-09-16, 09:11 PM
salimshah
salimshah's Avatar
hmm the wheel lugs are 76-78 ft-lb and require med to high torque wrench typically 18 inch or longer arm. You need to put your back into it to produce the torque.
The pan gasket requires 69 in-lbs ,,, and need the small torque wrench. Human wrist can produce that much torque.
Please confirm that it was not lb-ft which are 12 times higher. If you did then I think we need to tap one size higher for all.
Salim
Old 04-09-16, 10:25 PM
hsmac
hsmac's Avatar
Salim
You're right... it was ft lbs. I read the lbs part and immediately did not notice there was a inch lbs vs. Ft lbs, esp. since the wrench only shows one measurement for lbs. What a newbie mistake.
What happened was I read the 8 ft lbs for filter bolts and immediately read the 69 as more torque. Since there is not much torque perhaps it won't leak without the bolt after all.
Old 04-09-16, 10:29 PM
hsmac
hsmac's Avatar
in-lb right?
Salim
Salim you're a genius. It does go through but now I have the problem of figuring out how to catch on to the stuck shaft. Another bolt likely will just spin in place once it meets the other surface right? Maybe I'll try putting a tiny dab of epoxy glue. I figure pushing it out will be easier than reversing it back but who knows.
Old 04-09-16, 10:33 PM
hsmac
hsmac's Avatar
Does anyone know the size of the bolt and where I can get it? Local auto parts or dealet? I think the grade of fasteners at home depot is different from that of automotive fasteners?
I just googled and apparently someone broke that SAME exact bolt. What a coincidence. You guys won't be as dumb as me to overtorque but be careful with that one!
Old 04-10-16, 05:02 AM
fastnoypi
fastnoypi's Avatar
iirc they are 10mm heads with 8mm x 1.25 thread. Since its a light torque spec the grade will probably be 9.8 or 10.9 grade. Dealer parts counter should definitely have them. A local auto parts store should have them in the HELP! parts section or you can take a good pan bolt to an ace hardware if you are in a pinch to match up.
Old 04-10-16, 05:17 AM
thaeleelyr
thaeleelyr's Avatar
I thought 10.9 grade was the highest grade for metric (similar to grade 8 SAE) used for high torque applications, like suspension parts. I thought the inch-pound bolts were around 8 or less (metric, not SAE grade). Am I wrong on this?
Old 04-10-16, 05:27 AM
salimshah
salimshah's Avatar
For the snapped bolt, the issue is where to grab it. Front (pan side) you may not have enough shaft left. Try the back side and with pliers see if you can grab it with needle nose pliers. If the front is flat (will be able to go through the threads) then you need to ensure there is enough clearance in the back to pull it through and then twist is through. Determine this before you use the priers to damage the threads at the tip. If not then you have to use the tip (extended back) to back out the bolt from the front. If you do back out then quickly switch to the front as soon as you have enough length sticking out to grab. (preserve threads in the tip as they have to make their way through).
Once you past that hurdle, you will have to determine if the threads on the rest of the bolts are good. Back off each bolt and see if the threads are good and you can torque them to spec. For damages thread in bolt you need to get new bolts and for damaged threads in the holes, you will need to tap to the next size. Best would be get a new bolt to test out the threads in the hole and if you can torque a new bolt to spec, you are good.
If you have more than a few holes to tap then I suggest tap all as this will prevent future problems (which bolt goes with which holes).
To test, just take your current bolt to hardware or auto shop. Assuming your hole threads are good and the bolts are messed up, just buy them from the dealer.
For new I would suggest stainless (or consult auto parts). Make sure you get a matching tap. You can switch to non-metric but I would suggest stay with metric and try to use the same pitch of threads but go a mm size bigger. The application has more to do with rust than anything else, so the strength discussion is purely academic
The gasket will need to be replaced as overtorquing can cause leaks. Overtorquing can also mess-up the pan at the bolt points. If the dimples have been formed then they have to be flattened and pushed back. Use a ruler edge to see if the bolt holes have been pushed in. Hold the metal edge ruler on the the side and use a light source in the back.
Final word is that the level of fluid is higher than the joint. So dont try to slap things together.
Salim
Old 04-10-16, 05:42 AM
thaeleelyr
thaeleelyr's Avatar
hsmac: I found a schematic that shows how to determine bolt strength based on the markings on the head of the bolt but I can't get it to attach to the post. I'll see if I can PM it to you but if that doesn't work I can e-mail it.
Sometimes I have been able to progressively drill a sheared bolt until I can snap it with pliers and I'm able to remove the post without damage to the threads. Maybe you'll get lucky.
Old 04-10-16, 05:46 AM
thaeleelyr
thaeleelyr's Avatar
Nevermind, figured out a way to do it.
Quick Reply: bolt snapped in hole... what to do?
