One Brake Light out, Bulb's Fine, Fuse is Fine - Lexus 2001 RX300
So I had two brake lights out. I replaced the first bulb and that light works fine now. But after changing the second bulb, on the other side, that light didn't come on. I switched out bulbs and no luck. So it's not a bulb issue with the one light Also checked the #37 fuse on the driver side fusebox, and the fuse is fine. What could it be?
It can be the wire or socket is bad/corroded.
Salim
Salim
Check the wire folds on the bulb. Align them with the connector metal.
Take a voltmeter and see if you get voltage on the tabs of the connector. You may have to trace the wires to the it next junction point.
I dont like the device but the trailer installer have a device that punches through the insulation to touch the conductor inside the wire. You can make one by using a fine needle, but make sure you dont short things out.
Salim
Salim
Also, not counting the "third" brake light there are four lights total. Each side has two brake lamps - one on the hatch with the reverse lights and one on the frame with the turn signal/hazard lights. Which one is the issue and on which side (driver/passenger)
I hate to ask this, but just in case, did you double check the bulb number? There are two on the rear, 4770 (single filament) and 4773 (double filament). They look exactly alike. The double filament is a bit bigger and can't be used by mistake but you can accidentally install the single filament in the brake light, which will result in no lighting when the brake is depressed.
Also, are any other lights out, like your reverse or license plate?
There are two filaments in these bulbs - one for the constant "on" of the tail light and on that comes on when you press the brake. When you turn on your lights the bulb should be on constantly. Does it?
I will also check the other things you suggested (overall lights and such) when I'm back at home later today.
Thanks again for the help!
Fortunately, it's a memorable one, lol.
LexusLiife
RX - 3rd Gen (2010-2015)
06-07-18 12:22 PM
Bumbobee
02-24-09 09:09 PM
