Crankshaft Position Sensor Help Needed
I have a total of 4 keys. 2 keys with remotes (lock, unlock, etc) both are broken, but taped together.
I have a valet key and I have the flat key. The 2nd to the right is the key I've been using lately, and when car is locked and armed via the key, the security light goes red, solid red and stays on.
Ideas?
Ideas?
This thread doesn't actually describe the problem.
It asks how to check the sensor resistance, and if a bad sensor could cause no spark.
Are there any codes?
If you think there is an ignition problem,
http://lmgtfy.com/?q=RX300+Ignition+IG+pdf
Just going to keep going over it and hopefully figure it out, and sell it.
Thank you max.
Salim
I just figured out that my key will only lock the back door manually, but the key doesn't really turn.
So maybe this is the start of finding the solution.
Immobiliser is still showing solid red only.
Will post an update when I have one!
StarGS3
10-19-17 06:06 PM
kohatsu
03-03-14 02:44 PM
