Crankshaft Position Sensor Help Needed
Old 07-14-16, 12:40 PM
PrisyCrisy
PrisyCrisy's Avatar
Default Crankshaft position sensor Help !!!
How to check resistance at the crankshaft position sensor.
Where is a convenient place to access the wires?
If it has failed completely will that result in No spark at all??
Thanks,
Christa
Old 07-14-16, 05:37 PM
PrisyCrisy
PrisyCrisy's Avatar
Default Crankshaft Position Sensor Help Needed
Is there an easy way to check resistance at the crankshaft position sensor?
Is there an easy way to check the wire?
If the CPS has failed completely will this result in no spark at all?
Old 07-15-16, 05:45 AM
PrisyCrisy
PrisyCrisy's Avatar
Can anyone show me a picture or diagram looking down on the engine so I can locate the CPS ??
I have been unable to find anything other than a close up picture, which is not helping me.
For a 2003 Lexus RX300 V6 engine
Old 07-15-16, 06:26 AM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,110 Likes on 997 Posts
http://www.lexussouthatlantaparts.co...ssembly=767449
Down around the main pulley. I did not post earlier as I have limited info. To get to it most likely you will have to remove the main pulley and plastic cover. Its been a while ,,,, you may like to go over the timing belt DIY and see if the connector from CKP (your abbreviation) needs to be separated.
It is a robust piece. Not heard of dying out ... does not mean it can not happen.
No spark as I know is usually due to immobilizer, or ignition kill ... both are from ignition switch or key.
Salim
Old 07-15-16, 10:23 AM
PrisyCrisy
PrisyCrisy's Avatar
Found it, took out belt and headlamp and checked ohms. Reading came up 2100 ohms
Also checked front bank cam sensor and reading was 1100 ohms
Are these good numbers??
Also... Going to review the schematics I have, but would anyone happen to know what terminal to check also at the CPU ?
Old 07-15-16, 10:25 AM
PrisyCrisy
PrisyCrisy's Avatar
I will go over the ignition switch next.
The immobiliser seems to be working, although the light is steady on, not blinking...
Thoughts on that?
Old 07-16-16, 06:15 AM
Drcoffee
Drcoffee's Avatar
Just so people can see what you are talking about, the crank position sensor is at 1 o'clock on the crank pulley as you look at it from the front of the motor
Old 07-16-16, 02:39 PM
salimshah
Forum Moderator
salimshah's Avatar
Blink should go away when you insert the 'right' key.
DrCoffee ,, the engine looks too clean to be yours.
Salim
Old 07-16-16, 03:27 PM
PrisyCrisy
PrisyCrisy's Avatar
I have a total of 4 keys. 2 keys with remotes (lock, unlock, etc) both are broken, but taped together.
I have a valet key and I have the flat key. The 2nd to the right is the key I've been using lately, and when car is locked and armed via the key, the security light goes red, solid red and stays on.
Ideas?
Old 07-16-16, 03:28 PM
PrisyCrisy
PrisyCrisy's Avatar
Salem,
How many wires go to the crankshaft sensor? We only saw two. I thought there were three.... ?
Old 07-16-16, 04:08 PM
salimshah
Forum Moderator
salimshah's Avatar
Wires to/from CPS? Sorry no running knowledge.
Keys: I think I have covered it well in sticky ,,, having problems start here. If you need specific answer our resident expert is 'hypervish'. Please same time or wait for him to respond here.
When you insert one of the three plastic shell keys, the blinking light should turn off -> signature has been recognized and ignition kill has been deactivated [you will get spark].
Salim
Old 07-16-16, 05:01 PM
PrisyCrisy
PrisyCrisy's Avatar
Wires to/from crankshaft sensor.....
Scratch that... I gotcha
But which sticky? Is it by you?
Old 07-16-16, 05:46 PM
Drcoffee
Drcoffee's Avatar
Salim
Its not mine. I saved it from the web when I was looking into doing the timing belt on one of these beasts. It looks like a real PITA if you ask me. If you look close, that engine isnt even in the truck. Its on a hoist.
Old 07-16-16, 07:10 PM
salimshah
Forum Moderator
salimshah's Avatar
https://www.clublexus.com/forums/rx-...a-problem.html
No .. I dont claim anything is by me... all I have learnt (good and bad) is from others. .. but yes I am the thread starter.
Incidentally, I had left the thread open for others to contribute, but then members started to comment and or started to post their problems, so I had to lock it.
If any one wants to add something to even would like to get an answer to some common thing, please let me know.
Salim
Old 07-16-16, 09:50 PM
maxSteel
maxSteel's Avatar
This thread doesn't actually describe the problem.
It asks how to check the sensor resistance, and if a bad sensor could cause no spark.
Are there any codes?
If you think there is an ignition problem,
http://lmgtfy.com/?q=RX300+Ignition+IG+pdf
Quick Reply: Crankshaft Position Sensor Help Needed
