Knock Sensors #1 & #2
Are both knock sensors located close together so I could replace both at the same time?
Is this a good thing to do while everything is apart?
For the price of the sensors vs the labor, is it worth it to replace both at the same time?
How much are OEM knock sensors?
Private indy shop wants $1200 to replace knock sensor #2 and one O2 sensor. WOW
Thanks
Thanks
Thanks
Thanks
Once you open the top off, the two sensors are accessible at the same time and I would highly recommend replacing both at the same time and also the little wire harness.
You have parts and labor. Labor is roughly 6-8hrs although some one claims they have done it in 4. You can check with the shop about the book hours for the labor.
Salim
That $1200 is pretty close to the quotes I was getting when I had the P0330 code and was trying to decide to DIY this or pay someone else. Ultimately I decided to DIY. I spent more than 8 hours and thankfully had another vehicle to drive for the few days it took me to finish the project. But gained a lot of confidence while doing it.
One comment, if it is the #1 air/fuel sensor that needs to be replaced, The time to do it would be while the plenum is off to get to the knock sensors. I had replaced that sensor about a month before the knock sensor project. I really struggled trying to get to it from underneath in limited quarters. With the plenum off, that sensor was "right there". with easy access.
Thanks
Thanks
